slickooz
- Jan 5, 2010
This might be stupid question, but how do you guys remove the foam tips. I tried two times and gave up, didn't want to destroy the tips....
Ignore the people whose answer is "replace everything". Some people have yet to wrap their heads around the idea that we like our headphones to be conveniently mobile.
The iPod Touch 5th has an ruler flat output and can handle files up to 24/48. http://www.kenrockwell.com/apple/ipod-touch-5g/audio-quality.htm
Since 64GB is plenty of portable storage for all my FLAC/ALAC and I do not buy into the voodoo of high resolution music, the only function I miss with a boutique DAP would be a balanced output. A balanced DAP would cost 2-6 times what my humble iPod cost so I see no need or interest. Also, based upon reviewers like JAmato with an existing balanced amp (with phase split circuitry like my RSA F-35 Lightning) the added benefit of a balanced DAP is limited or negligible.
I have to find a short term solution to this. I don't mind upgrading my equipment, but I need to have a phone that works at least fairly well with my IEMs, because I take them everywhere. Does anyone here use them with the Galaxy S4? I can't be the only one!! Is this a known issue? It's not the audio quality that's the issue (it's actually not bad), but the popping sound is unacceptable. Any more ideas for a fix? Also, if I were to upgrade my phone at some point in the near future, which Android phone that can be used for at&t has the best audio quality?
To rule out the source, Do you hear popping noise with streaming also?
Found this regarding S4 - http://www.head-fi.org/t/662314/galaxy-s4-and-audio-crackling-issue-with-ue600
I do use my 846 with my Samsung S4 at the beginning until I got the X5. I never had this popping sound issue. What app are you using to play your music? Have you tried a different app and see if the problem still persists?
Hence it seems that as it was already pointed the S4 built in amp is not capable to deal with low impedance loads. Which is an unforgivable fault for a mobile device. It seems that Samsung is never able to ship rounded handhelds when it's not the gps is the screen or the amp.
After giving it some thought, I've decided that I'll probably purchase the Fiio X5 to go with my se846. There is a local store that I can demo it at later this week to make sure I like the sound of it. My thoughts are that it should offer a fairly nice SQ upgrade over my phone without breaking the bank too much, and if I want to add an external amp (Maybe even a balanced one? We'll see....) down the road, I can always do that. So I'll head in to demo that soon, and I plan on ordering a cable from the headphone lounge soon as well. I'll post my thoughts here when I get the new gear. Thank you all for your input!
I'm using PowerAmp. I tried the google app called "play music." Maybe I should try a few others players and see if any of them eliminate it altogether. It really only seems to happen on louder tracks, (such as The Call of Ktulu by Metallica) and at volume over 50%. The SE846 definitely can go way louder than any IEM I've had before (although the S4 sounds like crap driving them at high volumes)
Yes, but 535 and 846 are not the same design. The issue seems to be S4s amp not being able to drive low impedance IEMs.
535 is 36 ohms, whereas 846 is only 9 ohms. From the thread, I linked before.
I would recommend a dedicated DAP like X3, before you upgrade your phone.
I just did some more detailed playing with the equalizer in PowerAmp. I tried pulling each bar down to 0, one at a time to see if I could figure out where the popping is happening. When I pulled the 4k slider down to 0, all popping goes away. To me, that doesn't help understand anything, but perhaps to the more technically savvy folks here it might help explain exactly what the problem here is.
