I just received my Ted Allen SPC cable. It's super lightweight and the ear guides are much easier to mold. Also much more comfortable overall.
Not bad for $85
Not bad for $85
I went with the BaX over the Vocal or Music wires as did the Op of the thread regarding these cables which is highlighted on the front page of the site. I think his detailed review covers how they are constructed.
The BaX has a higher dB output than the other two types of cables in the Linum line but I was a little surprised to find that the stock Shure cable was louder than the BaX at the same volume settings.
Higher impedance will do thatCan't be thinner and lower impedance at the same time. By contrast the other after market cables would be louder than the Shure cable.
Clocking in as 846 user. Have this for almost 1 month, only use it when I travel pair it with Pico slim. Have SM64, ASG1 and JH13 classic. I rate this on par with JH13 classic. My gripe so far is that I wish it has more sparkle / extension on the treble and sometimes (depending on the recording) the bass can cloud the mid (some member here mention it already). Havent actually try other filters so I reserve my comments with the default filter.
I keep reading this - people wanting more treble out of the 846.
For more sparkle and treble, simply DO NOT USE FILTERS. Take them out and get the sound straight from the driver. The filters are pieces of plastic stuffed in the output nozzles, so, really, what would you expect? Something is going to be missing.
I talked to Shure about this and was told that you do not have to use filters, so I don't and as a result, I get a significantly different high end - much more sparkle and treble detail.
I'm still not sure which filter to keep using. Sometimes the blue filter sounds better than the white filter, but other times the white filter can sound better than the blue filter. There is no clear winner to me.
