- Jun 4, 2014
if there is one sure thing in the industry, it's that cable prices mean nothing.
just look into DIY, the "expensive" stuff is the plug.
I used to think exactly the same until I went and made myself a couple of cables. Unless you're buying in bulk by the ton, even just for an IEM, four strands of a sufficient length of good-quality silver litz alone will set you back about $100. Folks should try this as an exercise. Source, braid and solder your own silver litz cables. In terms of parts, you won't get much change from $150 and in terms of time, you won't get much change out of an entire weekend. Making these things by hand would have to be the worst kind of minimum wage job. Some of the fancier hand-braided cables (e.g., Kimber-AXIOS) for over-ear cans are real works of art and can contain a $LOT$ of Ag.
