So I decided to contact my "local" CIEM manufacturer to get another pair of custom sleeve ear-tips. I made impressions of my ears about 1,5-2 years ago and got custom sleeves for my Westone 4R which got stolen about 4-5 months ago. That's when I decided to grab the Shure SE846 as a replacement.
I have used Comply Foam T and S, or now known as Isolation and Comfort series and the Shure Olives for the past few months. I do enjoy Comply Foam a whole lot, I feel they provide great seal combined with great comfort. The problem is they don't last for very long.. It only takes about 2-3 weeks before they start to loosen up and not provide a great seal anymore, and the more they loosen up the more uncomfortable they get as I feel the need to pull them in and out of my ears all the time as I feel the compound gets warn and makes me entire ear canal warm.
Replacing them every 2-4 weeks is nonsensical due to their price.. The Shure Olives fares much better, they last for way longer but they don't provide the same great seal and comfort as Comply Foam. I find the Olives to be good, but not great. The seal is great unless I'm moving, laying down or using/moving my mouth. There is so little that needs to be done for the seal to break slightly. I don't find them as comfortable as they seems to push and irritate my ear canals a bit more compared to Comply Foam. The huge positive with the Shure Olives is the fact that they last for ages, at least compared to Comply Foam. I can use the Olives for months without their fit and feel starting to loosen up and they still look, feel and behaves like they are relatively new.
I also tried the foam offerings that came with my Westone 4R as they fit the Shure SE846 perfectly and some people seem to claim that the Westone ones strikes a balance between Comply Foam and Shure Olives. To be they simply felt like a inferior Shure Olives. They seem to have the same coating, ensuring that they will last way longer than Comply Foam, but I didn't feel like the Westone ones did anything better in terms of seal, fit and comfort compared to the Shure Olives and just like the Olives they did not provide the same seal, fit and comfort as Comply Foam.
I did also try the Triple Flange Tips and they just feel horrible in my ears. They do provide a great seal, not matter how much I move, no matter how much I talk and move my mouth the Triple Flange provides a perfect seal all the time. That doesn't really help when it feels like they turn my ear and head into a vacuum boiler.. I can't use them for more than a few minutes before I feel ill. I tried the trick of cutting of the third piece, making them into a Double Flange Tip but that didn't really help me much. It's not the length of the Triple Flange causing the issues for me, it's more due to how the silicon does not seem to fit my ear canals at all making them push way too hard all over my ear canal.
So long story short; I decided to get myself another set of custom sleeves. Yeah, it cost a lot but hey! They work great. It's not like custom sleeves provides 100% perfect seal all the time, they also have issues while laying down and when I move my mouth too much. But they provide a great seal and great comfort 95% of the time, and they have absolutely no issues with durability. I'd much rather pay for custom sleeves, instead of having to replace Comply Foams every 2-4 weeks thus ending up at the same price as simply buying custom sleeves after a short time.
I use a manufacturer called "Hantek". They are a Norwegian manufacturer that specialises in hearing aids and custom ear pieces. They have a deal or partnership with ACS for true custom in-ear monitors if you want something from the ground-up.
They still have my impressions so they can make me some new custom sleeves in no time. They are not entirely certain whether I would want to use my old impressions or get some new ones done. They claim they normally recommend taking new impressions every five years as the ear canals tend to change over time. But they admit that changes to the ear canal is less common when you get past the age of 20-22 and I did my impressions at the age of 24. Most changes comes at the result in fluctuation in weight etc.. But I've been the same weight for as long as I can remember. Should I get a new set of impressions done? That adds a lot of hassle on my part as getting to Hantek is easier said than done and it adds to the cost.
They do also sell Shure IEM's so they have much greater experience with sleeves for Shure compared to Westone so they even claim they can reshell my SE846 into a true custom IEM if I want.
I have no experience with reshelling IEM's. How "safe" is it? It sounds like risky business if you ask me. How can I be sure they manage to keep the same tonality and sound quality?
