Shure SE425 vs Sleek Audio SA6 vs Sony EX600
post-7595263
Thread Starter
Post #1 of 18
atptsoi
Which of these would you head-fiers get? I actually like a bit more bass without compromise to the treble though, I've heard these products one of the best at it's price and i'm in a huge dilemma on which one to get =/
Sleek Audio SA6 (Balanced Armature)
Sony EX600 (Balanced Armature?)
Shure SE425 (Dual Armature)
Im looking for a wide-ish soundstage with impacting bass as i'm a avid hiphop/rap etc. listener but I also occasionally monitor a stage so it kinda has to do both.
post-7596406
Post #2 of 18
takoyaki7
If Bass is a priority the EX-600 is definitely your best choice.
  And they aren't Balanced Armature, they are dynamics, which move air and generally much more heavier on bass.
post-7596702
Post #3 of 18
atptsoi
But reading the reviews, quie a few say that the bass is weak?
post-7596727
Post #4 of 18
TheGomdoRi
se425 is really neutral/flat and doesn't have much impact especially for sub kicks in hip-hop. I think I just helped you narrow it down to two
post-7597072
Post #5 of 18
atptsoi
For the sa6 which im leaniing towards,how is the bass? Feeling the thump?
post-7597352
Post #6 of 18
jankydude
SA6 you can definitely hear the bass. But you won't be able to feel it. Even on the bass ++ port with complys.
post-7597358
Post #7 of 18
ericp10
Sits up all night comparing IEMs.
Bass is not weak at all in the EX600, and I'm what some would call a borderline basshead (some would say I'm a full basshead).
post-7597442
Post #8 of 18
atptsoi
MMM, so bass wise, which of the two (ex600 and sa6) would you hear the thump more prominently?
post-7598206
Post #9 of 18
AstralStorm
I'd say none of the above have any decent bass.
Sony is likely just as expensive and has probably the worst bass timbre of all dynamics known to me, which makes it slightly worse than SA6's. It also suffers from mid overload and those mids aren't even close in quality to ones put out by SA6.
Shure SE425 are pretty similar to SA6, however with worse bass timbre (than bass++) and slightly worse high end extension. Detailing is on similar level. However, SE425 are priced ridiculously high compared to SA6-R.
To reiterate: do not buy SA6. Do buy SA6-R or something entirely different.
post-7598222
Post #10 of 18
Yggdrassilious
Really for hip-hop and for "impacting bass" you'd be better off with something other than the three you picked.
post-7598226
Post #11 of 18
music_4321
Have you actually heard the EX600?
I haven't heard the SA6 or SE425, but of all 21 phones listed in my sig, the Sony EX600 has some of the best bass response I've heard, with some of the very best timbre! Saying it "suffers from mid overload" is way off the mark - if anything, the mid-range might be considered slightly recessed (which I don't think it is, BTW). If you, in fact, have heard them, all I can say is you either had a (very) bad fit, a faulty pair (which is unlikely) or your concept of good sound is completely different to mine.
post-7598343
Post #12 of 18
Inks
An expert on his own opinion.
I agree with music. Of all the universals I've heard the EX600 is an outstanding performer.
post-7599010
Post #13 of 18
rolz
Astral has the words "likely" and "probably" in his reply, so something tells me he hasnt heard the new sony's
post-7600773
Post #14 of 18
AstralStorm
Actually I have, however I might have been exaggerating. The mid "overload" presents is a large ~3kHz hump. There's a minor amount of sibilance as well (noticeable as "hotter" sound). Maybe you're listening louder so the boost is less obvious or it's just my ears.
Bass is of course best of these three, they're dynamics after all, however it's nowhere near great. It's overly fast (yes, there is such a thing) and with not enough decay. GR07 beat the quality handily. It's good quantity though and there's not a lot midbass bleed, however it exists. Extension is ok. Soundstaging is pretty good, however the stage is a bit near and shallow.
They're pretty overpriced in many places. I see Amazon has for $150 - that's a good price, they're worth about that much. But here they're more to the tune of $250, which is unacceptable. (Brand markup like for Shure?) New Atrios are a better pick in my opinion at the lower price, the higher one and you can get IE8 or MTPG, which mop the floor with these in general.
(Note: IE8 at the lowest bass setting or +1. Anything above that is pretty much insane basshead mode.
The other two are more for fans of absolute mid and highs accuracy at the cost in bass quantity and decay.
SA6 are the smoother and lower mid based (not boosted!) sound, pretty linear though and among the best bass for an armature (with the b+ or b++ filter), it can compete with some multiple BA IEMs. Extension is ok bass side for a BA IEM, not that great in highs. The sound is rich in harmonics, sounding lush or reverb-like. Soundstaging is great with very deep insertion, which is trivial, since they're tiny and tiny nozzle diameter. Their main issue was build quality, specifically the cable. The newer ones should have a good cable, SA6-R has different cabling as well (incl. IEM-side plugs and sockets), but might sport some sound changes.
Shure SE425 are pretty neutral sounding, slightly harsher than SA6 and colder, a bit worse bass decay, far less lush. The key selling point of those over SA6 would be build quality. Soundstaging is in my opinion slightly inferior to SA6, certain kinds of percussion steps too much forward. They're also more expensive. Comfort is IMO slightly inferior too.
post-7600790
Post #15 of 18
music_4321
^ Well, we do hear things quite differently.
BTW, I'd take the EX600 over the IE8 any day - and I did enjoy the IE8s.  And I would pay $250 for the Sonys, too - better performers than quite a few $300+ IEMs.
