robm321
- Jan 12, 2006
That's certainly a possibility.
If only the shure instructions said something about itThat's certainly a possibility.
I too tried loads of different tips before finally going with custom moulds from Snugs, here in the UK (I’m sure there are others). They needed a bit of lubrication, but once heard, there’s been no going back for me. Superb bass, a real sense of ’immediacy’ and super sweet top-end.I went thru a whole conundrum with tips when I first got the KSE. Coming from the 846, I continued to use the yellow foamies, but treble fatigue happened, where it didn't on the 846 (obviously). I tried a multitude of options. Every tip in the Shure box, every Comply offering, every Spinfit, Symbio. Even to this day, haven't found the "perfect" one that hands down I can say is it. I stuck with the comfort Comply's for a while, which sound great, esp compared to the crappy Isolation ones, but found they don't go in deep enough. These days I just stick with the foam Olives, because they most balance everything (isolation, warmth, fit, clarity, soundstage, treble). Not the best particularly in any department, but satisfactory in every one. I dunno if anyone else feels the same.
Mine are the Snugs Only model from 2017. Looking at their website now, though, they have different models and I can’t find the the KSE listed as an option (the SE 846 is)! I’ve sent Snugs an email asking if they’re still available. I’ll come back here when they reply.Which Snugs model did you go for? Any other comments about these tips?
I went thru a whole conundrum with tips when I first got the KSE. Coming from the 846, I continued to use the yellow foamies, but treble fatigue happened, where it didn't on the 846 (obviously). I tried a multitude of options. Every tip in the Shure box, every Comply offering, every Spinfit, Symbio, Westone, Final E. Even to this day, haven't found the "perfect" one that hands down I can say is it. I stuck with the comfort Comply's for a while, which sound great, esp compared to the crappy Isolation ones, but found they don't go in deep enough. These days I just stick with the foam Olives, because they most balance everything (isolation, warmth, fit, clarity, soundstage, treble). Not the best particularly in any department, but satisfactory in every one. I dunno if anyone else feels the same.
A quick response from Snugs! They’ve updated their website to list the KSE1500 as an option for their SnugsPro (iem) models. I’ve suggested they add the 1200 to that list. The Pro (iem) is the same as my model but with a new name.Mine are the Snugs Only model from 2017. Looking at their website now, though, they have different models and I can’t find the the KSE listed as an option (the SE 846 is)! I’ve sent Snugs an email asking if they’re still available. I’ll come back here when they reply.
Shure olives are quite alright in terms of sound. I've got issue with their sizes unfortunately. Medium size is a little bit too small and I easily loose the seal and big ones are too big and I can force them in but they are uncomfortable after a while.
What’s your recommended eartips for KSE?
Following up on my own post, the XELASTEC arrived. It’s unbelievable for vocals, giving them front and centre stage with lots of presence, separating it from the rest of the music. Bass thump is still there, but mid-bass lines that may colour the vocal range seems gone. Treble texture from cymbals is still there. My favourite pop and vocal tips.I like Symbio W hybrid (thin silicon outside but with foam inside) Has a wide bore but I use it with an adapter borrowed from my Spinfit. This pairing has deep bass but without affecting mids and treble (unlike Final E type, and Earrbond Barreleye, both tame the highs and details)
Have the XELASTEC coming next week.
I just got the kse1500 one for mine and used some of the foam that came inside it to pack the bottom out.Where do i find protective case for the kse1200 energizer?
