HoodedHoodlum
105 just to be safe it never clips
Thanks for the info!
I recently had an opportunity to have almost entire range of Empire Ears to compare with my KSE1200.
Legend X
Nemesis
Vantage
Valkyrie
Phantom
EVR
Bravado
I can say that if you're a fan od KSE you can safely skip all of them unless you want something completely opposite.
Thats an interesting and punchy short summary! I was thinking about trying a couple of the new EE ones. I have the KSE1200, which I’m enjoying very much.
When you say “completely opposite”, any extra colour to add?
I’m using the biflange tips that sit relatively deep in the ear. I tried the Spinfits but they sit a bit shallower and thus causes some sibilance (supposedly due to the additional reflective surface area). The tips and how they sit in your ear really do make a big difference.
What bi-flange tips? Don't the KSE come with only triple or single flange?
This morning 1200 amp suddenly can not turn on, can not charging.
It's a heart takening moment. I thought I must send it for repair.
Tonight I check a gain. Lucky, there's a tiny hole at the bottom. No text nearby but I know it is reset button.
Press it 3s and try again.
Yeah! Turned on. OK
