TYATYA
Ah I understood. You diy the black foam padWhat do you Mean ? Thé box is a simple IKEA box with some foam that indeed i cut to the right size and internal Shape
Beautiful !After many different combo & cable testing, here is my latest set-up: AK1000SP + Shure KSE1500 with MandarinES eartips (red diameter adaptor needed) + Brimar cable. All fit in an IKEA case...
A long way since the TU-05 Amp + AK100 + Fostex TH900 pictured above post (still a very good sound but... much less portable ! )
Endgame ? You never know !
I did try the spiral dots, but I had the impression that the Shure kse bore was overly exposed and I became afraid that dirt or wax could get inside the headphone. did had the time to compare spiral dots vs spin fit. did you had the same impression?One way to make a suitable silicone tube is to cut the head of the Shure soft flex tips. I did this so I could try mounting JVC spiral dot tips and have to say there was a noticable improvement over foam tips, base was better controlled along with excellent top end extension.
The other advantage of the spiral dot is that they have a bigger range of sizes than most so getting the ideal fit is a little easier.
New brother of 1500
I do and I will have them Saturday. They are the Sensaphonics custom Sleeves (SCS) . I have had the SCS for 3+ years for my Shure 846.. Can't hand any of the Universal's.. Not only are they super comfortable excelent seal yadda yadda yadda they did improve the over all wider soundstage. ...Just like to say at this point that NO tips work for me (ever, small ears, unusual ear shape, whatever - short of using duct tape and a hammer they simply won't stay in) - so I use Snugs custom molds.
I was surprised to see Shure KSE1500 / 1200 are on the list of models Snugs can make for.
Does anyone here have their KSE's in custom molds?
Yes I do.Just like to say at this point that NO tips work for me (ever, small ears, unusual ear shape, whatever - short of using duct tape and a hammer they simply won't stay in) - so I use Snugs custom molds.
Beautiful !
I have tried several eartip. For me, shure black foam kills the shure kse... you lose soundstage, lose hi frequency extension and some micro detail.
I’m using spin fit 800, and with that the kse it’s almost like focal utopia with a super hi end amplifier
I want to try those symbios. They probably even better.
If you like the spinfit 800's, try the spinfit twin blades. CP240.
The best sealing I've found. I've tried everything, and the 800's where my goto until I recently found the CP240's. So good, you need to be careful when removing the IEM.
Imagine a modular DAC chip so we can update or use different DAC flavors.when would shure release a version engerizer with built in LDAC bluetooth please?
the built in DAC is also of so so quality, please update!
thanks.
