TYATYA
How effective is it when you're carrying your device in your pocket?
If thinking like that you can ask a same question to Brimar audio when they stick their round pad on chip top face, inside the mojo dac. They call it mod for mojo.
I am user, not much understood how piezon material works... I guess it is something like dynamic to electric energy transfering and just use it.
Your question is right.
I think of the same, but I didnt digging how it works when in my pocket - a soft enviroinment.
The pad use on many surface as in manual where it contact to the air so how does it work (kill vibratio) may be product's maker can answer
Did you know each time touching the dap screen (my dap is sp1k, said about it, not sure if others daps) it make a audio noise? I seems to like put my dap upside down when I listen to it.
Some headfi here also comment they feel the difference if daps in cover compare to no cover use...
Those things are questionable.
I dont know how much it effect on my dap BUT I wont peel of it out of the dap, and kse too.
For my desktop amp, hdvd800 I can tell more about effect and where to stick those pad.
Stranging to the pad, I use it as extra usage that didnt write by Japanes company : stick on a cd! Ofcouse I must hear some diference.
After I found this wonderful thing, I go to their website to digging and found : there is exactly a special product to do the job - stick on cd (or magnet piece holder to keep the disc)
