Shure AONIC 50 -
Aug 20, 2023 at 5:56 PM Post #1,262 of 1,309
Aug 21, 2023 at 4:24 AM Post #1,263 of 1,309
Sad to say my bluetooth in these just died. This unit was a replacement for a model where the pads had detached, so I've had it less than 6 months. I noticed my sound went from fine to constant stutter if I turned my head with the usb cable charging. 1 day later and now wont connect at all and if I forget device it doesn't show up in the bluetooth device list on my phone or PC. Bitter that they're probably out of warranty and I'll be out $300 if I want to replace. Are there any viable alternatives? I love the sound quality/signature, environment mode/ANC switch and being able to use them cabled as well as wirelessly.
Honestly for the same amount of money, even if you don't game, the Audeze Maxwell is worth a serious look as a replacement if you don't have a warranty claim. i think they have better tonality and the default balanced eq audeze created is really well done. If you wanted to make adjustments you could, and you can store 4 eqs in the headphones themselves and toggle between them. i've been pleasantly surprised by them. They are not bass monsters by default, so any eq you might make to get a similar sound to the Aonic50 I don't imagine would be to drastic.
Aug 31, 2023 at 12:28 PM Post #1,264 of 1,309
Aug 31, 2023 at 3:44 PM Post #1,265 of 1,309
Also on the Shure page now:
https://www.shure.com/en-US/products/headphones/aonic50?variant=SBH50G2-BK
399€... I'll probably pass, I already have too many Bluetooth headphones and hardly use them if at all. I'm also not interested in sound processing for spatial audio -- to me completely useless with music (OK for films, but also not necessary).
The case looks much more compact, they still only fold flat though. I like the black color scheme. Did not find any info if the pads are deeper now. 45h runtime sounds nice.
Replacement pads are also mentioned as part Nr. SBH50G2-BK-PADS
Sep 1, 2023 at 12:58 AM Post #1,266 of 1,309
I have these, the bose 300 whatever and the fancy Sony anc something. I prefer the Sony, as the anc is the best on them. They are all close tho, can't really go wrong with any of them.
Sep 2, 2023 at 1:43 AM Post #1,267 of 1,309
Sep 2, 2023 at 9:53 AM Post #1,269 of 1,309
The Shure website says these support "aptX™, aptX™ HD, aptX™ Adaptive, AAC, SBC and Sony LDAC." Looks like aptX-LL was dropped, but one web review says it still has that codec; I sent an inquiry to Shure. My Aonic 50 are sitting with my TV because they have LL, which is the only context with which I use them these days.
Sep 4, 2023 at 4:59 PM Post #1,270 of 1,309
APTX LL was dropped after adaptive was introduced. adaptive is supposed to be the balance between audio quality, stable connectivity and keeping video and audio synced.
Heres a link from qualcomm describing aptx adaptive.
https://www.aptx.com/aptx-adaptive
Sep 4, 2023 at 6:26 PM Post #1,271 of 1,309
My understanding is that the latency in adaptive isn't as low as LL.
Sep 4, 2023 at 7:19 PM Post #1,272 of 1,309
I think adaptive was meant to try and bring the best of APTX HD and APTX LL in to one codec. It has a lower bitrate than APTX HD, 576 KBPS to 420 iirc, and I believe APTX LL has latency of 32MS to something like 80 for adaptive.
Sep 15, 2023 at 12:49 AM Post #1,273 of 1,309
If they haven't fixed the anc, these aren't worth it. Anc on in a closed environment, the Gen 1's aren't touchable.
Outdoors, there are better choices for ANC, although those come with a lower audio quality.
Edit:
From what I've read, they tweaked the sound, that could be even more of a deal breaker.
Half the reason people pick Shure is the flat, neutral stage.
Sep 16, 2023 at 8:59 AM Post #1,274 of 1,309
Hey all,
Anyone compared aonic 50 to momentum 4? I have a best buy gift card and thinking about picking up the latter
Sep 16, 2023 at 1:29 PM Post #1,275 of 1,309
Well, I went ahead and ordered the Gen 2, maxwell, and momentum 4 to compare. Can't afford to keep all 3, but it can come out of my account for 2 weeks before going back in. lol
