JML
I'm waiting to see what the new Fidelio L4 sounds like...
Curious about the momentum4. i love the Maxwell personally.Well, I went ahead and ordered the Gen 2, maxwell, and momentum 4 to compare. Can't afford to keep all 3, but it can come out of my account for 2 weeks before going back in. lol
Momentum is really good! Aonic 50 gen 2 arrives tomorrow. Maxwell on Wednesday.Curious about the momentum4. i love the Maxwell personally.
Hi Josh, can you give a descriptive comparison between Aonic 50 and Maxwell. Cannot find anything specific about in the forum. I tend to prefer planar headphones but cheap implementations of them are usually disappointing. Still I am quite curious about a closed planar.Side note: the momentum 4 are great and portable, but for at home, the Maxwell are brilliant and sound flipping fantastic. Huge rec. Great for gaming and music. Sound better than my go pods with monarch mkii
Hey man,Hi Josh, can you give a descriptive comparison between Aonic 50 and Maxwell. Cannot find anything specific about in the forum. I tend to prefer planar headphones but cheap implementations of them are usually disappointing. Still I am quite curious about a closed planar.
Thanks.
Thanks,Hey man,
I don't know how technical I can get, but in broad terms, the maxwell is more detailed/resolving, has a wider stage, and has better bass. It sounds really good. Plus 80 hour battery life! Best BT I've heard. Definitely superior to the aonic 50, and I was a fan of the 50. It's still good, but the maxwell is better. Not portable though. Fine for around the house but I wouldn't go to the gym with them.
EQ settings are not stored in the headset and therefore only works with the Aonic player. That player is not great anyway, so you are better off using Poweramp or USBAudio, where you can EQ even with LDAC. No idea if that Deezer app has an EQ.Hey Guys! I'm new here( From Germany) and i am an Aonic 50 (cream/white) Owner since 2 days now..
Very happy with them since so far.. The Options to listen over BT, AnalogCable and USB-C are perfect for me, cause i wanted a HP for commuting and home..
For the 169€( somewhaat like 1:1 for Dollars) i bought them new from Shure directly.. A NOOOBrainer thats for "SURE"
Now i am a little confused in Terms of Codecs and EQ Settings..
For me, as an Android User, Honor 70, only AptxHD and LDAC are Options.
But there are a few Things i still dont really understand.
The Shure APP provides an EQ, ok, but when is it really available, only on AptxHD and lower ?
If then, is it also for my Deezer HiFi Option available or do i have to listen via Shure APP?
And how and when are the "hardcoded" EQ Presets directly loadable on the Headphones? With both Codecs?
I only want to use them with Deezer and they should be little tuned... 2-2,5 db in 2 frequency areas.
i could live with the out-of.-the-Box tuning, but would like to give them a little 60-100 Hz bumbp and a slightly little tame at 8-12 khZ
Can you please elaborate a little bit more on this? thanks!This is not true anymore… that was already changed for gen 1 with one of the software updates
