HiFlight
@HiFlight, would you mind taking measurements of the earcup dimensions on the 1540? And then the inner space?
At the highest and widest points, they measure: 2 5/8" high x 1 3/4" wide and 1" deep.
Actually after further comparisons, I like the 1840's with the 1540 pads better than the stock 1540. The 1540 with the 1840 pad significantly reduces the bass level.
How about 1840's with the stock velour pads versus the 1540's with the 1840 pads? I'm sorry if this is becoming annoying, just curious
Edit: Would you also mind mentioning what exactly you like about the 1840 with the 1540's pads compared to the stock 1540. Thanks a lot!! It's not just for me, it's for all the Head-Fiers who are interested.
Thanks, so about 66mm long and 45mm wide and 25mm deep. Great, perfect size (those measurements are the inner space for your ears right?)
The 1840 with the 1540 pads seems overall warmer, but still well balanced tonally. Bass extends deeper and makes me feel I am missing nothing on the low end. Sine sweeps are pretty linear.
IMO, the 1540 pads work better on the 1840 than the 1840 velour pads work on the 1540. The 1540 response is more V-shaped than the 1840 and the highs seem to be to be brighter with the 1840 pads on the 1540 than the stock 1840.
I felt that the bass (probably more accurate to say "lower mid-bass") on the stock 1540 was overemphasized relative to the rest of the audio spectrum, at least for my listening preferences. Using the 1540 pads on my 1840 adds bass evenly and I am not perceiving that same sensation of over-emphasis that I did with the 1540. The closed backs of the 1540 also warms my ears more than the 1840. Still, I think it will all boil down to personal preferences. I am just not a big fan of V-shaped sound contours.
The 1540 clearly offers considerably more isolation than does the open-back 1840. This is noticeable on the first listen.
I also noted that the construction of the cables was different on the exterior with the 1540 having a beefier strain relief at the "Y" and round cable as opposed to the 1840 zip-cable design. I don't know if the interior wiring is the same or different as I have only done surgery on the cable from my 1840.
I hope this helps...
Hmmm I am closing in on a Modded Wooden Back D2k... I wonder if these would be a step above the Denons! Granted less bass... but possibly better mids and highs :O still no wood so... that leaves my w1000x a sad girl. Seeing as she want's another wooden friend <3
Still might have to give these a listen some day >.>
I'll just say... HOLY BASSSSSSS!!!
What?!?!
I'm guessing yours have arrived? Impressions?
Yes, impressions, impressions!
