Starfinder
just got my Tape from amazon uk. do going to listen till Christmas but might try and burn them in before, any advice, white noise? if so for how long ?
All these reviews saying Vx bass slam doesnt resemble an all BA set. Would be a fun comparison$2100 GDC Anole VX 10 BA iem vs a shuoer EJ07 Tribrid iem at $850 seems cool but not at all and apple to oranges comparison.
I wanna confirm this. So my left unit went silent today. Took of the wax guard and it surprisingly works. No idea why. But I put the wax guard back in and it still works. Thank you for thisas soon as I removed that mesh screen, the driver got to its normal performance...the wider sound comes with extra details without the screen. The 3-4k spike gets even more pronounced.but with eq those with OCD may prefer the no screen extra details and even wider sound field.
Until someone does an A/B comparison between the ST7 and EJ07, we won't know if they sound 100% identical or not. It certainly sounds like a steal for the ST7 to be $300 less than the EJ07 (based on aliexpress prices), but it also just seems fishy. My thought is that perhaps the **** uses b-stock or is built using a different process. The EJ07 are built to order, not sure if ST7 follows the same fab process. It would be a benefit to the community to know what you get with the EJ07 over the ST7, if anything.Hey, apparently new ST7 come exactly the same as Shuoer with Knowles BAs. If you search in twitter you will see some pics from japanese buyers and they are identical.
Apparently my version was some early version which used Sonion BA units and new version is different in tuning. I don't know to be honest.
I can say that Linsoul Shuoer and current Aliexpress OEM are exactly the same. However if you search Shuoer EJ07 on Taobao you will find a little different version which I've got.
I don't know if there was an issue with getting access to Sonion BAs or new tuning is better or something else but apparently my sample is one of a kind and cannot be bought right now.
I wonder how the new sample sounds though.
I digged a little deeper and apparently my unit has Sonion 2389 and it has only one BA unit inside each shell - mine looks exactly like this:
https://item.taobao.com/item.htm?spm=a21wu.10013406.0.0.689f72e9MHrue3&id=599538199302
However, new ones seem to be with Knowles and has 2 BAs. Apparently factory sent me some initial sample. I don't know if new samples are improved or if production costs are cut but Balanced Armature parts are different, crossover is different and dampfer tuning is different.
You can't get my version anyways though so no reason to care about it I guess. New version always comes with Knowles Dual Ba no matter how you name it.
For what it's worth, I ordered that exact model you linked on taobao direct from shuoer. It is supposed to ship today. The seller has been texting my phone (in chinese) giving me fabrication updates. Very happy with the shuoer customer service so far. Should have it by early next week.
How exactly do you remove the mesh/filters? Any link to a tutorial?
I used a sewing needle. The wax guard itself is glued but you can lift it up with the needle. You can put it back after removing and it should still sticks.
I ordered ST7 on 11.11 and had to wait untill Dec 3rd for production end. I think it is the same process. I'm still waiting for the delivery though.The EJ07 are built to order, not sure if ST7 follows the same fab process.
I've ordered mine from the same seller. Had same fake tracking, that was cancelled by timeout, same DHL attempt after, but they don't deliver within Russia so now the parcell is going via AE Standard.Waiting on my ST7. Didn't get a VIP update process - had to chase the AE store after fake shipping info (finally posted 12/12 after ordering 11/11), and now hopefully will get them Monday.
It's a little odd - after a few weeks they offered the st7 with the black faceplate from the st6, which I've also seen on some Shuoer EJ07 as well, as they said they didn't have the usual green in stock.
