Uncle Erik
Uncle Exotic
- Mar 18, 2006
X2 on joining Badger & Blade, or just lurking to read how to shave correctly. I never really had trouble with ingrowns, but used to get razorburn and had trouble getting a few tough patches.
Since I switched fully to DE and learned to do it right, I have no irritation and perfect shaves that last 5-6 hours longer than a cartridge shave. Done right, you barely notice that you're shaving at all and the aftershave doesn't sting, either. It can be slow going the first few months while you adjust and learn, though. Early on, it'd take me a good 30-40 minutes to shave. Now it's about 10-15. You'll also spend some time going through a couple dozen brands of blades until you find the right one for you. Blades are very individual.
Anyhow, give it a try. There are some pricey razors and brushes, but the inexpensive ones work well. Also, you're going to find a world of products, so there's a lot to see and try. And compared to audio, everything seems very inexpensive.
