Shanling MW200 Hi-Fi Bluetooth neckband adapter - BT 5.0 , AK4377A DAC/AMP, supports LDAC, LHDC, aptX HD, aptX LL
Sep 15, 2020 at 3:04 AM Post #61 of 168
I have tried the MW200 with couple different pair of IEMs. The MW200 is more than sufficient for the low impedance and high sensitivity IEMs and it drives those really well.
It pairs great with my Andromeda Gold/Andromeda S/Andromeda 2020 and fairly well with the Ibasso IT01s as well.
However, the MW200 will have trouble with harder to drive IEMs (eg BGVP Zero) and seems to struggle to put out enough power to drive them well. The BGVP Zero has thin bass and thin treble when paired with MW200 even at max volume. But USB dongles have no trouble driving the BGVP Zeros to their fullest.......
Sep 15, 2020 at 3:12 AM Post #62 of 168
Hopefully they come out with a with a 0.78mm version!
Should be on market in November.
Max volume on both the MW200 and your phone? MW200 is not as powerful as UP2 or UP4, but so far we didn't found any IEMs that would demand too much from it. Will try to look up how is this BGVP model set-up.
Nov 16, 2020 at 2:37 AM Post #64 of 168
Folks, I cannot find it in the manual. But what's the maximum number of devices that can be paired with mw200? Also is there any way to see the list / manage paired devices?
Will check with software team if there is some limit on our devices, but if yes, do not think anybody hit it yet.
There is no way how to view currently paired devices or how to delete them.
Nov 23, 2020 at 8:36 PM Post #65 of 168
How to use MW200 as USB DAC? I connected the MW200 USB C port to computer USB C. When turn on the MW200 it went to pairing mode. Tried multiple time and it does not seems to be able to connect to a notebook PC. Can you provide the steps and picture if possible?
Nov 23, 2020 at 9:09 PM Post #66 of 168
You just connect it to computer, turn it on and then it should show up in sound settings and you are good to go.
I would advice to use different cable and different port if possible, we saw some cases when MW200 doesn't work properly with USB-C to USB-C cable.
Nov 23, 2020 at 10:35 PM Post #67 of 168
Another scenarios, if I want to connect the MW200 to Shanling M6 Pro's USB C port to listen music directly without bluetooth, can it be done?
Nov 23, 2020 at 10:57 PM Post #68 of 168
Yes, that can work.
Dec 5, 2020 at 1:33 AM Post #69 of 168
Hi guys, im new here and been looking at "1More EHD9001BA", "FiiO LC-BT2", and "Shanling MW200".
Any updates on this product?
Are the parts same since it was launched or are there any improved versions of it?
Is the over ear hook part moldable or of permanent shape?
If moldable, does it has metal wire or do we need to apply some heat for it to mold over our ears?
Thank you so much.
Dec 6, 2020 at 8:37 PM Post #72 of 168
Thank you so much.
MW200 is released to international markets, you can check with your local distirbutor of Shanling for availability.
It was launched two months ago, so the parts are the same,
Earhooks are pre-shaped, you would need to use heat to change the shape. They do not use the metal wire.
Any recommendation on the type of USB C to USB C cable for connecting NW200 to M6 Pro. Tried several cables it does not work.
USB-C cables seems to be picky about this connection. So far it seems using USB-C OTG adapter and standard USB-A to USB-C cable works better.
Dec 9, 2020 at 11:07 PM Post #73 of 168
I will most likely be getting this from Aliexpress. How is your support here if i get this MW200 from Aliexpress?
Dec 10, 2020 at 12:06 AM Post #74 of 168
Can your review how the usb c conection auto detect? I think there are issues on how it recognize the connected device. For example, sometime I can connect to my laptop usb c and in other cases it don't work.
Also you Shanling App, can it be trigger via phone USB c rather than bluetooth.
Dec 10, 2020 at 12:50 AM Post #75 of 168
If you buy on Aliexpress, you warranty will be only with the Aliexpress seller. https://en.shanling.com/category/256
But of course I can give you some advice or troubleshooting on the MW200.
Anytime you connect MW200, you need to turn it on (even if it was turned on before) and once you start playing music, it should switch into USB DAC mode.
But if you are connecting to USB-C port, we got some reports that MW200 doesn't work with USB-C ports, if you use certain USB-C to USB-C cables.
Shanling controller app only works via Bluetooth.
