Shanling M8 Android Portable player
Jun 20, 2022 at 4:32 AM Post #4,981 of 5,905
#Shanling -
I just, like an idiot, updated the firmware to the latest version. And now I can no longer get Android File Transfer to work on my Mac. I keep getting the attached message, even when I select "Transfer Files" from the device USB menu. I have rebooted my Mac and the M8 many times.
Any suggestions?
Also, I see your programmers have still not figured out how to alphabetize: "The Rolling Stone" continues to get listed before "The Beatles." Sacrilege. Will you EVER fix this? It really should not be that difficult and would be much appreciated.
Jun 20, 2022 at 9:18 PM Post #4,982 of 5,905
Hi, unfortunately we do not have Mac to troubleshoot this. Would you be able to test it with any other Mac or preferably Windows machine?
Sorting of "The" in our app is unchanged, not sure if or when it would be fixed.
Jun 21, 2022 at 4:37 AM Post #4,983 of 5,905
Well, thanks for the reply. Will try to test it. Or just see if I can revert to the previous firmware.
Re. Sorting - that is pretty sad.
Jun 21, 2022 at 4:53 AM Post #4,984 of 5,905
Not owner but maybe you could try OpenMTP?
Those looking for Android File Transfer alternative Mac may want to give OpenMTP a shot. This file transfer software is designed for macOS and Android devices and it’s free and open source.
https://openmtp.ganeshrvel.com/
Jun 21, 2022 at 12:57 PM Post #4,985 of 5,905
Worked like a charm. Tip much appreciated! Was able to use it to revert back to the prior firmware, which does indeed work with AFT.
Jul 1, 2022 at 9:58 PM Post #4,987 of 5,905
Just burned my LCD-X in for 250 hours...the soundstage has just expanded significantly. Soundstage seems to have no limitations now...Listening on my M8...3D holographic...
Jul 4, 2022 at 9:30 PM Post #4,989 of 5,905
Anyone here sorted the volume knob problem? It doesn't work most of the times.
What exact problem? With click (that would mean damaged inner button) or with volume (that would be inaccuracy in the potentiometer).
Jul 5, 2022 at 2:33 AM Post #4,990 of 5,905
The volume doesn't increase or decrease. The click works perfect. When rotating the wheel, the volume bar shows the volume digits increasing or decreasing but the volume level doesn't change.
Jul 5, 2022 at 2:56 AM Post #4,991 of 5,905
Sending you PM.
Jul 5, 2022 at 9:38 AM Post #4,993 of 5,905
Try reconnecting your headphone. Works for me every time.
Jul 5, 2022 at 4:54 PM Post #4,995 of 5,905
I have a problem with my M8, since yesterday I have the black screen so for navigation it’s a real hassle, I put the music on my playlist but impossible to see where I am.
I tried a reset but still the same problem, I would like to know how much it can cost to change the LCD screen when it is no longer guaranteed.
thank you
