When we could see first reviews?
Shanling M7 - Qualcomm 665 CPU, ESS ES9038PRO DAC, Android 10, 5-inch screen
- Thread starter Shanling
SibilantGoose
First review: https://inf.news/en/digital/03b58555773cdd02cd7efbe0e333f5eb.html
Unfortunately they are really into verbiage but not into comparison. Yet, they are mentioning player being close to M9, warm and technical
psawjack
- Aug 28, 2015
So the output power listed for 4.4 balanced is 900mw. IS that total output power or per channel? I get confused with that stuff.
Thanks!
Thanks!
We always publish output per channel.So the output power listed for 4.4 balanced is 900mw. IS that total output power or per channel? I get confused with that stuff.
Thanks!
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
psawjack
- Aug 28, 2015
Thank you for the info.We always publish output per channel.
I received the M7 yesterday. I hope to get time to use it more today! Great job on it Shanling!
Congrats and enjoy! Looking forward to your impressions of it!Thank you for the info.
psawjack
- Aug 28, 2015
Does anybody have a list of what the various dap filters mean to the sound?
psawjack
- Aug 28, 2015
So one minor annoyance is that I can't switch Android launchers. I downloaded one and tried to set as default but when I hit home it goes back to Shanling launcher. I don't like Shanling launcher because it behaves like iPhone, no app drawer all apps have to be in a home page
These issues are due to the way how our software team implemented the Prime Mode. It's causing problems with alternative launchers, which is why the player is stuck at the default one. They say there is no fix for this.So one minor annoyance is that I can't switch Android launchers. I downloaded one and tried to set as default but when I hit home it goes back to Shanling launcher. I don't like Shanling launcher because it behaves like iPhone, no app drawer all apps have to be in a home page![]()
Is there a M7 pro planned ?
psawjack
- Aug 28, 2015
Thanks for the information. Could I request an app drawer for the default?These issues are due to the way how our software team implemented the Prime Mode. It's causing problems with alternative launchers, which is why the player is stuck at the default one. They say there is no fix for this.
No.
I can try to check with software team, but not sure if they would be willing to switch to different launcher for this.
I purchased the @Shanling M7 in store from @Audio46 here in New York City. I noticed some weird things when I started the player up, that I want to see if they are normal for this player. This is my first DAP over $1,000.
1. The box was wrapped in plastic when I got it, so it seemed brand new, but when I turned on the player for the first time, it went right to the home screen and everything was in Chinese, it didn’t give me the option to choose a language at start up. Is this normal?
2. I then played around with some settings and scanned my SD card. The battery went down from 50% to 43%. I then turned off the player overnight. When I turned on the player this morning, the battery life went UP to 47%? Is the battery reader not accurate, or is there something wrong with the battery/DAP?
3. I listened in Prime mode, single ended, medium gain, 48 volume for only 20 minutes during my commute this morning. The player was at 45% when I started listening but went down a full 6% in that 20min span. That would be only 5.5 hours of battery life which is about half of what the battery should be in single ended mode. Does it seem like there is a problem with the DAP?
sungmj
- Feb 13, 2010
I'm wondering how easy to open one up and try different op amp?
1. It can sometimes happen if the factorty forgets to do factory reset after finishing QC. If you will have any issue with changing language, please check this PDF: https://drive.google.com/file/d/1YGwEHdJg20u38jU7fpmVqr9HaiDwHOty/view?usp=sharing
2. & 3. If you have brand new player, I would recommend to firstly charge it and use it first time before making any guess about accuracy of battery meter.
