my M7 asking me before download to what directory,so,tidal im downloading to internal memory,all my other music im sent to microSD 512gb.Can I download albums from Tidal to a micro sd card on the M6U? If so, please guide me. Thank you in advance for your reply.
Shanling M6 Ultra - 4x AKM AK4493S DAC, Snapdragon 665, Android 10 DAP
- Thread starter Shanling
Thank you for a quick response. I'm just going to buy the card, so that's why I'm curious.
Yes, you can, it's setting within Tidal app.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
ChaiTeac
This might have been posted before, but has anyone managed to get a third party equaliser app like Wavelet or Poweramp EQ to work with the AGLO system this player is using?
Even the built-in equalisers for Spotify and Pulsar are non-functional. The only app that has an equaliser that works is UAPP.
I've tried with Wavelet to enable both permissions by going into developer options for DUMP permission but still the eq doesn't change anything about the sound.
e-dub
Is it possible to use an SD card formated on APFS with Shanling players?
doors97426
which m6 pro uses different dac chips then shanling likes to use was it the m6 pro 21 i have the m6pro and m6pro 21 and the m6ultra i thought i read one of has a less warm sound and more brighter sound i thought it was the 21 after the chip factory had a fire i want use the brighter less warmer sound with my NAD amp which has a warm sound thanks for any help
anandgiridhar
- Apr 26, 2015
From my not directly related experience, there is an option in wavelet settings for legacy mode. Did you switch that on and try? That worked for me for some other usage purpose.
It was reported to our software team, will see if they can adjust our system for it in any way.
Isn't that like the proprietary Apple formatting? Don't think that works on anything outside of Mac.
Out of these three, the M6 Pro 21 would be the most neutral, while M6 Ultra the most warm.
From our current line, M7 would be the most neutral sounding.
Have you enabled Advanced Player Tracking in Poweramp EQ via ADB? Should work with most players (at least it works for me with plexamp)This might have been posted before, but has anyone managed to get a third party equaliser app like Wavelet or Poweramp EQ to work with the AGLO system this player is using?
e-dub
What formatting can I use for an SD card to use with Shanling devices?
We use standard exfat on all our cards.What formatting can I use for an SD card to use with Shanling devices?
e-dub
But is that the only one that works, or are there other formats?We use standard exfat on all our cards.
For the cards most common are FAT32, exfat and NTFS. All 3 will work on our players, exfat is simply our preference as it seems to be the most universal among other devices.
You can read about the differences here for example: https://www.howtogeek.com/235596/whats-the-difference-between-fat32-exfat-and-ntfs/
Bought a second-hand M6U and installed Wavelet on it and it was working just fine.
However, when I did a Shanling firmware update Wavelet (and other EQ apps) appear to no longer work. Unfortunately I made the mistake of not making a note of what version of the firmware I was one when it was working.
Hopefully, this gets resolved in a future firmware update but if anyone needs EQ apps at the moment, it might be advisable to roll-back firmware (if that's even possible)
