Is the wifi so slow you cant stream with it? Mine has been working fine at work and at home. At work I'm on wpa2 at home I'm on wpa3. My understanding is the bug is related to the security protocol you are using in the wifi access point. Some are not working with wpa2 very well. if you change your protocal to wpa3 which is a better protocal anyways as wpa2 is pretty useless as far as securing your wifi network these days anyways.Yes, I primarily listen to Apple Music and as of now do not know of anything that I can use for EQ. Power Amp worked for a while and then after the last couple of updates became so unstable I just took it off the player. I find myself just listening to music with my iPhone instead... which is kind of a waste.![]()
We are only on wpa2 at work because my boss thinks not all our devices can do wpa3 but I'm pretty sure she's wrong about that and I'm trying to get her to change her mind about it lol
