anandgiridhar
- Apr 26, 2015
@Shanling if I'm correct, the M6U is on Android 11 now, is it likely to be updated to Android 12? Thanks,
Really, you make me laugh!!!@Shanling if I'm correct, the M6U is on Android 11 now, is it likely to be updated to Android 12? Thanks,
yep, from there track record, they never provide update to new android version.Really, you make me laugh!!!
It's Android 10 and will stay on Android 10!
If you mean iBasso, dx240 got update but only Android 11The only Android version upgrade I know of is the DX300 MAX, from Android 11 to 12. There may have been more but it is pretty rare.
Oh ok! Thanks! Somehow I got the impression that it gotten upgraded. Well, ten it is!Really, you make me laugh!!!
I've had trouble with Wifi when transferring more than just a few songs. It's slow, and also would have trouble with certain songs, repeatedly delivering them corrupted.Wifi speeds are very slow on m6 ultra,
Didn't faced issue like this on my fiio m11 plus ess.
Firmware 1.28
Our software team reported they have fix for this issue and it will be released with next firmware update.Wifi speeds are very slow on m6 ultra,
Firmware 1.28
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Well, the two models you listing are earbuds, which is quite a niche category and for quite specific user scenarios.Hello everybody. please tell me which headphones you use in a pair with Shanling M6 Ultra for listening to music, namely heavy metal. and which headphones you can recommend for future purchase. at this point I was recommended Yincrow RW-3000 and Fiio EM5
i own Shanling m6 m6 2020 and the m6u Im using the m6u .my question is my m6 and m6 2020 both have the battery go to zero in about 3 days ,if i dont keep them charged will it kil the battery or do i have to keep them charged. i even turn them off and they seem to drain. my m6u i use 30 min a day during my lunch break and it stays charged for about a week and a half. is there something wrong with the m6 and m6 2020
thank you for your responceWell, the two models you listing are earbuds, which is quite a niche category and for quite specific user scenarios.
It would help to know if you are looking for earbuds, isolating earphones/IEMs or actual overhead headphones.
They are older models, so it might be simply battery degradation over time.
Good day. the following models were the leaders in the listWell, the two models you listing are earbuds, which is quite a niche category and for quite specific user scenarios.
