Shanling M6 Ultra - 4x AKM AK4493S DAC, Snapdragon 665, Android 10 DAP
Aug 2, 2023 at 11:50 PM Post #781 of 873
We are looking into this Roon ARC issue. Latest firmware adjusted how our system works with sound from some 3rd party apps (Before update, Roon would play, but completely muted), so it's possible that while we fixed it for the main Roon app, the Roon ARC now got this new issue.
Aug 13, 2023 at 6:09 PM Post #782 of 873
@Shanling
Just updated my M6U to firmware version 1.3.
Tidal MAX (HiRes FLAC) quality songs now all play in silence over Bluetooth in my car. :unamused:
Correction : Some Tidal HIGH quality songs are also affected and play in silence.
Wired headphone playback does not seem to be affected.
I also tested with my Galaxy S23 Ultra and it played Tidal MAX songs over Bluetooth just fine in my car.
I also noticed an increase in M6U sound quality when playing non Tidal MAX songs over Bluetooth. Not sure if that's due to Tidal updates or M6U updates, but I like it. :relaxed:
Where can I get the previous version (1.28?) of the M6U firmware to test?
The workaround for now is to set Downloads > Audio quality to HIGH. (I only play downloaded songs in my car)
You can still set Audio & Playback > Mobile Data Streaming and Wi-Fi Streaming to MAX.
Aug 13, 2023 at 8:31 PM Post #785 of 873
@Shanling
Tidal HIGH/LOW quality songs are not affected and wired headphone playback is not affected.
Hi, please which type of Max files? Currently there seem to be 3 kinds of Max file - full 24/192 Hi-Res, MQA files that still opena s MQA and recent MQA files that now play only at 24/48
Hi- I updated to the new firmware and since then can't seem to be able to use my bluetooth headphones anymore.
It connects fine but then can't hear any music. Any troubleshooting advice ?
Please what headphones and which codec?
Aug 13, 2023 at 8:46 PM Post #787 of 873
Interesting that bluetooth doesn't work with tidal. I also have qobuz and no issues there. Why o why ???
I'm listening to downloaded files. I tried my Ibasso DX170 and no issues there with bt and tidal.
Update: I uninstalled Tidal and re-installed on my 6U and now it works.
Aug 13, 2023 at 8:50 PM Post #788 of 873
Ok, so your issue is also limited just to Tidal, to Max files?
Aug 15, 2023 at 4:58 AM Post #791 of 873
@Shanling I had a HIGH file in Tidal play in silence today, so the issue is not limited to MAX songs over BT.
Also, MAX is not MQA, just HiRes FLAC.
Please what file was it?
MAX includes both Hi-Res Flac and MQA files.
Aug 15, 2023 at 8:40 PM Post #792 of 873
@Shanling - Just to add to the list of issues on the latest update
The update didn't fix my slower WiFi speeds
The EQ apps work but Wavelet has a static like noise when first engaged while playing music through Apple Music and Amazon Music. I have to toggle the wavelet app on and off to get rid of the static.
However, Poweramp Equalizer also has the static but it does not go away no matter what I do. It also slows the music that's playing to where it cuts in and out in addition to the static.
Aug 15, 2023 at 9:05 PM Post #793 of 873
Noted.
Aug 15, 2023 at 9:06 PM Post #794 of 873
I had to remove the Wavelet app as it was causing severe distortion when playing Amazon Music and Radio Paradise. Took a while to just narrow it down to the Wavelet app causing the problem.
And I'm not absolutely sure yet, but it seems the Wifi speeds are actually slower now on my M6U as compared to before.
