Shanling M6 Ultra - 4x AKM AK4493S DAC, Snapdragon 665, Android 10 DAP
Jul 27, 2023 at 9:38 PM Post #766 of 873
Bought a second-hand M6U and installed Wavelet on it and it was working just fine.
However, when I did a Shanling firmware update Wavelet (and other EQ apps) appear to no longer work. Unfortunately I made the mistake of not making a note of what version of the firmware I was one when it was working.
Hopefully, this gets resolved in a future firmware update but if anyone needs EQ apps at the moment, it might be advisable to roll-back firmware (if that's even possible)
It's in works, I believe new firmware for M3 Ultra has it now fixed (Alongside fix for Roon).
Jul 27, 2023 at 10:06 PM Post #767 of 873
Thanks for the update.
Beside from the EQ (which I don’t use much in any case) it is a lovely DAP! :gs1000smile:
Jul 31, 2023 at 4:15 AM Post #769 of 873
Jul 31, 2023 at 4:48 AM Post #770 of 873
Firmware Update Released
Go to the website for full notes and download link:
https://en.shanling.com/article-FirmUpdateJuly23.html
Thank you for the firmware update link!
But what was changed in version 1.3 (July23-update)?
Update Notes for M9 Plus/M9/M7/M6 Ultra/M3 Ultra:
1. Added system-wide support of LHDC 5.0
2. Fixed playback issue of certain 3rd party apps (Roon, Chrome and others)
3. Fixed issue causing Bluetooth Amp Mode to be silent
4. Optimized MicroSD card compatibility and recognition speed
5. Shanling Music - Added support for embedded Lyrics
6. Shanling Music – Optimized Library Update Speed
7. Other fixes and improvements
Does this update include the requested/discussed updates for system wide EQ and WLAN speed?
Jul 31, 2023 at 5:25 AM Post #771 of 873
I've downloaded the update and confirm that Wavelet now works. In terms of WLAN speed, I was not having any issues with this previously so I cannot comment on this .
Jul 31, 2023 at 3:47 PM Post #772 of 873
I've downloaded the update also but I´m in trouble to install it. The screen 'update in progress, don´t shut down' shows for an hour and nothing else happens. The player has 1.28 installed, I made a factory reset, took my 1 TB Sandisk card out and switched even to english. Any additional ideas?
Aug 2, 2023 at 11:45 AM Post #776 of 873
I'm not sure about others on this thread but the update did not fix the slow wi fi speeds for me.
It all depend on the router you use:
In my case the speed is OK on a Asus AX88U router (with Merlin firmware v388.2) - I get ~200 Mbps down and ~50 Mbps up (on a 500/50 line) on 5 GHz AC-type WLAN with 80 MHz channel (433 Mbps connection from M6U).
Aug 2, 2023 at 12:13 PM Post #777 of 873
Note: We recommend downloading the file and proceeding with a Manual update, as OTA update might be too slow.
Can I play music from the Ron ARC normally?
I keep getting "Unexpected Playback Error"
my M6U is on 1.30 now.
Aug 2, 2023 at 3:24 PM Post #780 of 873
This new version broke Poweramp Pro for me, but only when using Bluetooth. The Shanling app in bluetooth works so most likely settings within Poweramp pro. I use the default settings but can't seem to get the bluetooth working. Does anyone know how to fix this?
  • Back
