kr0mka
- Aug 18, 2015
1. Added music streaming media: Tidal. (limited to Tidal Hi-Fi and Online playback only)
Does this mean there will be no Tidal Premium support? Or will it be added in future update?
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
On my unit it was fixed with 3.0 firmware. Can you try to take video showing, how severe is your problem?.
I've been successful in importing Relative Path Playlists and the M5s reads & plays them BUT they don't show up in my Playlist lists. I've created a folder called playlists, and imported the playlists using JRiver and it works great when I use folder view and go to the playlist folder, but is there anyway to have them show up as a playlist in the menu?
No, it doesn'tIs it just me or does the M5s sound better with the new 3.0 update?
No, it doesn't
Cutting-edge artisanal in-ear monitors for discerning listeners. Proudly designed and manufactured in Singapore.
Stay updated on Subtonic Audio at their sponsor profile on Head-Fi.
for me it got better with bluetooth streaming mode... it just felt different and under powered compared to playing directly from SD card before, now i streamed spotify almost as good as my flac fileIs it just me or does the M5s sound better with the new 3.0 update?
What Astel & Kern model do you have? How do you compare it vs M5s?I can honestly say that a couple of weeks ago I made a comment to my wife in reference to the M5s that "the more I use it, the better this thing is sounding" I attributed it to 2 things: 1. My getting used to it after so long with an Astel & Kern unit and 2. More burning in time. Then I saw this post and realized that my comment almost exactly coincided with the update to 3.0.... Hmmmm
Further testing on m5s SE and Bal. Bal is warmer and bassier. Balanced seems to have sharper and more defined imaging providing more control and separation for my DD ciems. on the other hand, SE is less warm, has a more forward midrange which sound more normal to me tonally (in synergy with my iem). However basslines do get a bit flabby and uncontrolled. Decisions, decisions..
