Shanling M5s now with TIDAL - Dual AK4493EQ DAC, fully balanced, Wi-Fi, 2way LDAC BT, 3.2 Touch screen, FW 3.7
May 14, 2019 at 11:08 PM Post #2,041 of 2,497
@Shanling
Great job on the interface though one thing it lacks that I hope you'll implement is bitrate information of the songs in the Now Playing screen. Please? :pray:
May 15, 2019 at 10:59 AM Post #2,042 of 2,497
@Shanling
Is it possible to add a A-B section repeat function? That would be awesome.
May 15, 2019 at 11:56 PM Post #2,043 of 2,497
Hot damn this player makes my Oriolos Mk2s sing!
May 16, 2019 at 12:43 AM Post #2,045 of 2,497
2.5mm balanced output?
Yes.
Shanling knows how to put soul into their DAPs that draws you into the music and gives you eargasms. It’s the same with the M3s cept this player has a better stage and more details/separation.
May 16, 2019 at 7:38 AM Post #2,047 of 2,497
@equalspeace : just curious, do you also have mod balanced cable for the Sennheiser HD 6xx ? I only used the stock one for my Sennheiser HD598. But now the Audeze iSine 10 with balanced cable outperforms the HD598...
With my HD6xx I use a Corpse cable with a 2.5 mm termination. I also have the 4.4mm cable that Senn makes, but I don’t get to use that too often these days. I’m just holding on to it incase something great comes along w that output. When I had the Fiio Q1 Mk2 it drove my 6xxs surprsingly well with the Corpse cable.
May 16, 2019 at 5:21 PM Post #2,053 of 2,497
Thanks for the link! Is this firmware file compatible with my US Shanling M5s player or is this only for Chinese M5s players?
there is no region difference, you can flash it on any m5s :)
@Shanling
Bitrate information is there :) you just have to tap the album art and scroll twice to the right.
May 20, 2019 at 3:56 AM Post #2,055 of 2,497
So @toranku how do find the M5S after spending some time living with it?
Haven't had the time to compare to SR15 and ZX300 actually. Other than that, very happy with the UI, battery life and noise floor. Its really tough to find something with a low noise floor these days and they fit the bill well.
Other than the wheel being sensitive and changing volumes whenever I put it in my pocket, I find no problem with it since I set it to not be able to adjust volume when screen is off.
Subtonic Audio Cutting-edge artisanal in-ear monitors for discerning listeners. Proudly designed and manufactured in Singapore. Stay updated on Subtonic Audio at their sponsor profile on Head-Fi.
https://www.facebook.com/Subtonic.Audio https://www.instagram.com/subtonicaudio https://subtonic.audio support@subtonic.audio
