I certainly do - and I’ve been using them quite a bit with the M5s. And really enjoying the combination.
I’m using the Moon Audio Bronze Dragon with them though to run them balanced...
I’ve stitched some screenshots together of the EQ I’m using for the iSine 20 (to get a similar sound to the cipher cable). It really helps balance the sound and brings out the treble with a lot of airyness and clarity.
Unfortunately testing car stereo system's is way above our possibilities. I can only advice to set M5s to basic SBC codec and look into BT setting in your car.
Thank you for your answer, that's unfortunate. I tried switching to SBC but it still connects for only 1s then disconnect. I know you said that it is beyond your possibilities, but theoretically speaking, can this issue be fixed through a FW update?
Also, does the M0 have the same BT spec as the M5S? I am looking for something to replace my iPod in my car, so hopefully, the M0 is different.
Im really excited. I never thought that vaporizing is so much more fun than cigarettes. I can take a short puff or a long puff and can decide for myself if i get a small or big flash. But the tendence is to inhalate longer. Its a joy and pleasure to breathe out the smoke clouds. Very satisfying. I wonder if i have the same feeling when i lower the amount of nicotine. I like the throat-hit. 92 puffs now. If i imagine doing this with a cigarette i think i would start feeling uncomfortable now.
Formerly known as ihatepopupads Headphoneus Supremus
Just got mine today, nice device but boy for a plus 400 dollar device the screen is really crappy ‘way too warm’ and low rez (although saturated nice) Anyways the sound is just too warm atm and I’m burning it in hoping it gains some more treble energy and detail.
As it is I’d take the zx300 over it (weird reverb effect and all) and against the sr15 it’s no contest. Even the AP80 sounds more energetic.
The stage is nice though, oh and I need to try to change themes because I’m hitting the scrub button every time I hit play/ pause on the screen.
I don’t want to sound too harsh- it sounds really nice so far just not my cup of tea. Ok back to burn in.
I am having a freezing issue with firmware 2.0 is anyone else having this issue?
I have 140GB out of 256gb card majority Flac redbook with maybe 20%mp3. I have no dsd files.
When I am playing music from an album and scrolling through either ‘artists’ or ‘albums’ the device will freeze after about 10-25 seconds of fast(?)scrolling.
The song that is playing when the device freezes will continue to play until the song is over and it cannot be paused or next track using the buttons on the outside and the volume wheel will not change the volume either.
The only way to unfreeze it is to hold the power button in for 6ish seconds until the device resets.
I have duplicated this just by use over the last 2 weeks by it happening on all different songs and albums. Is this normal from scrolling too fast or something? Is this just a bug and I should scroll slowly until and update comes in or is it just an issue with my individual device?
I had the same issue. Try restoring to factory defaults and rescanning your card. My player kinda worked itself out of this issue after using it for a while.
We can try to change different things, but without knowing what's causing problem, so pretty much without having access to Acura 2016, we would be only guessing what's going on.
M0 uses same system, so likely it will work the same.
Did you tested your M5s with some other BT devices?
Click on album art on now playing screen and scroll to left twice. You can read Advanced user manual, posted on first page, to learn more details about M5s' system.
Thanks for replying. I tried to connect the M5S to my BT headphones and they all work fine. I also tried to connect it to my old Sony BTV5 speaker and it also works, so I guess it is not compatible with my car for some reasons.
Also, my car is a 2016 Accord. I wish it was a Acura lol
