Shanling M3X Portable Player - Our smallest Android Player
Aug 9, 2021 at 1:45 PM Post #1,366 of 2,445
Talking about Shanling Music player? That's strange, as the firmware update should never delete data from the app.
And it wasn't possible to just move tracks in the playlist.
I've lost all my EQ setting with the firmware update, so this doesn't surprise me.
But i didn't care, i use Neutron as my main music player.
Aug 9, 2021 at 8:58 PM Post #1,367 of 2,445
@Shanling , I have a problem with Google Music. And the songs do not change automatically. I have to turn on the M3X again and again so that at the end of one song the next song is played. This is very tedious and annoying. What is the problem here? Please test once and give feedback. Thank you
Google Music? Wasn't it completely replaced by Youtube Music?
I reported these app resets to software team to check.
Aug 10, 2021 at 12:04 PM Post #1,368 of 2,445
@Shanling , sorry i mean Youtube Music. Not Google Music. That's my mistake... The Problem is with Youtube Music... Please fix this...
Aug 11, 2021 at 10:18 AM Post #1,369 of 2,445
@Shanling this is a ridiculous request, but is it possible to roll out an update that will add an option to add some bass boost to the sound output? I currently turn on the high gain to have the same. No I do not like to use eq.
Aug 11, 2021 at 8:35 PM Post #1,370 of 2,445
So you don't want to use EQ, but are asking us to add in some software wide EQ?
We do not alter sound with firmware updates.
Aug 11, 2021 at 9:58 PM Post #1,372 of 2,445
I asked for an option, not a permanent change. But yeah, stupid request, my bad.
Aug 11, 2021 at 10:22 PM Post #1,373 of 2,445
Same here, i’m fine with eq but the build in don’t have much control and i still don’t find any reliable system wide eq at least compatible with spotify and shanling player, ended buying xd05 basic for a bit more power and bass boost
Aug 12, 2021 at 12:56 AM Post #1,374 of 2,445
Same here, i’m fine with eq but the build in don’t have much control and i still don’t find any reliable system wide eq at least compatible with spotify and shanling player, ended buying xd05 basic for a bit more power and bass boostE407291D-5A95-4A09-8F21-9EA8AE5BD617.jpeg
I turn on the high gain to get a bit boost in bass.
Aug 12, 2021 at 2:17 AM Post #1,375 of 2,445
I myself use an XD05 Bal for the bass boost with the M3X.
Aug 12, 2021 at 9:48 AM Post #1,376 of 2,445
Oh yeah, Using M2M jack from M3X to xd05 basic i noticed more energetic and a bit rumbly bass on high gain on Blessing 2, it is tad more better bass without bass boost, all this time i’m using low gain…
Aug 12, 2021 at 10:51 AM Post #1,377 of 2,445
This player has performed beautifully, both in single ended and balanced mode. I run Amazon HD music exclusively. However, if I shut the player down completely, I am noticing at least a 10-13% battery drop every night. If I leave the player shutdown for a week, it will be completely dead. Is there a setting I'm not aware of to stop this?
Am I the only one with this issue? Anyone? Bueller....?
Aug 12, 2021 at 2:41 PM Post #1,380 of 2,445
Doesn't poweramp systemwide EQ work? Or wavelet perhaps? Poweramp EQhas 30 band if I remember right
Playing with them is too much work...
