I dont think hiby r3 pro saber is android though
Yeah, thanks for the correction. Was thinking only about the streaming services! Sorry!
Where did you order it from? I am in the UK and I cannot find it anywhere. Hifiheadphones said that they won't be stocking it anymoreHello, i just ordered m3x limited as my first DAP after only using ios for years, i’m using Blessing 2 with Qudelix 5k right now, can’t live without the eq, and B2 and B2Dusk is not just $10-20 in my country
Is there any system wide eq that works with spotify and local player? Thanks
Hiifiheadphones is the uk stockists, but are sold out right now. You could email them to find out if they are going to get more in.Where did you order it from? I am in the UK and I cannot find it anywhere.
Thanks buddy, done that but they said they won't be stocking it anymore (Hiifiheadphones is the uk stockists, but are sold out right now. You could email them to find out if they are going to get more in.
okay,LED is active only when charging, turning on device and when using Bluetooth.
I am having frequent WiFi disconnects even after a complete reset. This is getting very frustrating as I cannot stream any music without the music stopping due to the WiFi disconnects. I tried resetting my router and still the issue persists. I also went to multiple Internet places like coffee shop and library and I still have the WiFi disconnects. I also verified that the WiFi network the DAP is connecting to is 2.4 GHz. Looks like I have a busted WiFi component in this device ...@Osiris89 .. I just saw your post .. I just picked up this unit from one of the head-fi members .. it just got to me today and I too am having similar WiFi issues ... my Shanling M5s connects without any issues, so something seems strange that it is happening to M3x. I am on the latest 1.4 firmware. I scanned this thread and everyone confirms very strong WiFi connection. I am going to try a reset and fully charge the device. I saw some prompt on the device on Battery Optimization that can cause WiFi disconnects .. I checked and no battery optimization is enabled on the device in any of the apps.
Try letsgoaudio you will need to email them and they charge around £35 for shipping via FedEx.Where did you order it from? I am in the UK and I cannot find it anywhere. Hifiheadphones said that they won't be stocking it anymore
There is one on ebay, located in uk. Not very good price though, I don't know what about warranty.Where did you order it from? I am in the UK and I cannot find it anywhere. Hifiheadphones said that they won't be stocking it anymore
@Shanling .. anything I can try to get this issue resolved or should I just send this back to MusicTek for a replacement?
LED light might not be completely accurate. There is no other way how to check.okay,
is it when in charged at >90% the led automatically off ? mine like this all the time.
how im supposed to know that the device full charged without pushing the on button everytime ?
thank you
He's getting this message Shanling. He got the unit off me and it was fine with my router. But as you can see he keeps getting disconnected
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
If it was working fine before but facing issues now, either something happened to it later or there is some software glitch.
You can send it back to seller for them to check on the unit, if behaves out of standard.
This can be sometime bug of Android. Sometimes it can be fixed by simple restart of the machine. For some users it helps to enable SUB debugging in developer options.Hey guys. As from today, when I connect my M3X to the computer and open the SDcard folder, it appears as empty. There's still files there and I can play them all in the player, but can't see them on Windows...
Anyone know a fix for this?
