nekromantik
- Jul 30, 2009
anyone got output power at 16 ohms for 3.5mm and balanced?
Just double the listed mw per channel on the specs. They're @ 32 ohm. So single end about 200 mw and balanced about 400 mwanyone got output power at 16 ohms for 3.5mm and balanced?
I thought its not always as simple as that as some players has a voltage cut off at lower ohms etcJust double the listed mw per channel on the specs. They're @ 32 ohm. So single end about 200 mw and balanced about 400 mw
Same here. As I noted yesterday, to get the same volume out of a far more expensive and higher power DAP, iv had to almost double the volume over the M3X. I don't know what wizardry Shanling pulled off with this thing but it's power output or at least perceived power output is way above its stated numbers. It likely has to do with the amplification circuit being part of the DAC chips. This is how they get this to out out more than decent power power with good battery conservation. Based on the M3X I think ill pick up the M6 Pro 21. It should be a winner.I can tell you the m3x is the first dap I've used low gain.
If i could second guess, its thier Shanling custom coded FPGA chipsets and KDS Femto grade oscillators that have a DNA of M8 that makes the difference.Same here. As I noted yesterday, to get the same volume out of a far more expensive and higher power DAP, iv had to almost double the volume over the M3X. I don't know what wizardry Shanling pulled off with this thing but it's power output or at least perceived power output is way above its stated numbers. It likely has to do with the amplification circuit being part of the DAC chips. This is how they get this to out out more than decent power power with good battery conservation. Based on the M3X I think ill pick up the M6 Pro 21. It should be a winner.
Yeah I got Dorado 2020 which is 10 ohm IEM but it needs power to get best out of it. So need low impedance but high output DAP.Output impedance is less than 1 ohm so those numbers should be true. I'm sure Shanling can tell you.
Depends on sensitivity of the phones/iems also. There's a chart floating around that will tell you output power needed to drive various iems and cans. I can tell you the m3x is the first dap I've used low gain.
It's already on HiFi Go for $799 up from $759 of previous M6 ProYeah I got Dorado 2020 which is 10 ohm IEM but it needs power to get best out of it. So need low impedance but high output DAP.
Was lookin at M6 21 but with the Pro 21 coming with better battery may wait. However price will be higher of course.
yeah thats most likely the Chinese version without Google PlayIt's already on HiFi Go for $799 up from $759 of previous M6 Pro
where do you going to order this and how much duty you expected to pay ?I have finalized on XD05 Balanced.
I dont know. I think Shanling had said that its current releases are all international version and Hifi Go does handle international market. I've written to HF Go to confirm its in stock and International but havent heard back yet.yeah thats most likely the Chinese version without Google Play
I’ve got mine from Hifigo and I can confirm it’s an international versionI dont know. I think Shanling had said that its current releases are all international version and Hifi Go does handle international market. I've written to HF Go to confirm its in stock and International but havent heard back yet.
M6 Pro 21?I’ve got mine from Hifigo and I can confirm it’s an international version
There is nothing like Chinese or international variant for M6 Pro21. They are all the same.yeah thats most likely the Chinese version without Google Play
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
