Shanling M3X Portable Player - Our smallest Android Player
Nov 17, 2022 at 3:13 AM Post #2,176 of 2,512
Mine arrieved today with same issue!!
Could either of you try to make a short video or audio recording, if you would be able to capture the sound?
Can only think it to be either loose battery (normally glued to the back panel) or loose shielding panel inside.
Nov 17, 2022 at 7:52 PM Post #2,180 of 2,512
Nov 22, 2022 at 7:14 PM Post #2,183 of 2,512
Inspecting closer, I can actually see the case back moving a fraction of a mm. It's the case back knocking on the chassis.
@Shanling is the case back glued on?
I dont think it is. Mine has gotten loose or popped off a couple of times when I've dropped it. I snapped it back on.
Nov 22, 2022 at 9:35 PM Post #2,184 of 2,512
It's held in place by plastic prongs and bit of glue.
Nov 23, 2022 at 7:54 AM Post #2,186 of 2,512
Maybe this is kind of a funny question, for @Shanling and anyone who might know... but is there a reason to worry about wearing out the jack on the player by plugging in and unplugging headphones every day, or several times a day? I ask because I remember that my old Sansa player could be used for a few months before the jack would just stop working. And it was the same story with my ipod shuffle. (Yes these are both cheap, older players.) So with Shanling players, like the M3X, I've been leaving the primary headphones I use connected all the time so that doesnt happen, wrapping the cord around the player when not in use. But it's not great for the cord, or the IEMs for that matter, as they arent in their own case. So... nothing to worry about here, no issue? Do the headphone jacks just stop working from overuse... or does that never really happen? I'd like the jacks and players to last as long as possible, several years. (If it matters, I'm always using the balanced jack. On both the M2X and M3X).
Nov 23, 2022 at 7:59 PM Post #2,187 of 2,512
No, if you are just inserting headphones for normal daily use, it will have no impact on the device.
Nov 23, 2022 at 8:14 PM Post #2,188 of 2,512
Excellent, thanks, good to hear. I imagine it could be a few times a day of attaching and removing. But thats normal daily use... if its no issue, great.
Nov 23, 2022 at 8:46 PM Post #2,189 of 2,512
Hola a todos, tengo mi shanling m3x hace medio año y quiero saber si puedo conectarlo a unos parlantes activos para poder reproducir mi música a través de ellos, tengo parlantes klipsch r51 pm y me gustaría poder reproducir mi música shanling a través de ellos, ¿cómo podría conectarlos? Espero que me puedas ayudar, gracias. Ah, una cosa, espero que la conexión sea por cable, no por Bluetooth.
Nov 23, 2022 at 10:12 PM Post #2,190 of 2,512
Hello everyone, I have my shanling m3x half a year ago and I want to know if I can connect it to some active speakers so that I can play my music through them, I have klipsch r51 pm speakers and I would like to be able to play my shanling music through them, can I? how can i connect them? I hope you can help me, thank you. Oh, one thing, I hope the connection is wired, not Bluetooth.
