Shanling M3s - dual AK4490 DAC, 2.5 balanced out, aptX BT, HiBy link, USB out, FW 1.7
Jul 5, 2018 at 11:19 AM Post #1,877 of 2,219
@Shanling I'm impressed my M3S works with my JDS Labs EL Dac AND my Singxer X1 via USB but the volume is super low? Any ideas why
If you're on the latest firmware, turn the volume up to 100 on the M3s. For firmware versions above 3.0 there is a mistake in the software that allows for the digital volume to be changed. Not sure why Shanling hasn't fixed it.
Jul 5, 2018 at 12:34 PM Post #1,878 of 2,219
Hello. Is there any other way to update the software? In the "System Settings", the items "Update Firmware" and "Reset Settings" are missing. I can not do a reset or update the firmware in a standard way. Is there any combination of buttons? To update the player if it does not turn on.
Jul 5, 2018 at 12:40 PM Post #1,879 of 2,219
Thanks, I figured it was something like this but I had no time last night to try that! Wife got upset that I was setting up the speakers so I just did a quick plug n play
Jul 5, 2018 at 1:49 PM Post #1,880 of 2,219
We solved the problem on player.ru. You need to turn off the player. Press the "Play" and "Power button" buttons. The process of updating the firmware will begin.
Pre-throw the firmware file on the memory card. The firmware 1.6 is defective.
Jul 5, 2018 at 9:22 PM Post #1,881 of 2,219
We would like to fix things, but system on M3s isn't developed by us.
Can you please take photo of this? What firmware are you on?
What is defective???
Jul 6, 2018 at 4:32 AM Post #1,884 of 2,219
Firmware 1.6 update Shanling M3s:
Download from Google drive
New functions:
1. Added setting of wheel sensitivity (4 most sensitive, 1 least sensitive)
Changes and fixes:
1. Fixed problem of Bluetooth pairing with Sennheiser wireless headphones
Jul 8, 2018 at 9:55 PM Post #1,889 of 2,219
I’m on firmware 1.5. When connected to the ifi micro idsd BL via USB, the M3S volume is very low. I need to turn up the ifi volume or set the m3s volume very high. Is this normal?
Unfortunately part of HiBy software, when digital volume affects digital output with some DACs.
1.6 uploaded succesfully. Still bugs with polish fonts in menu, and wheel sensitive menu only in chinese. Besides Hiby Instruction only in chinese :cold_sweat:
Did you downloaded version from our website or from Dropbox? Dropbox should have the version with fixed chinese in menu.
With Polish fonts, unfortunately we can't help you.
