AndySocial
"For now" is code for "never gonna happen."How high is this feature on your to-do list, if I may ask?
Why? is it broken? Below is a comparison.Hi all... So I've been a happy Shanling M2s owner for a couple of years and it's time to replace it.
I was traveling with my M2S all day yesterday. Still sounds fantastic with my IEM's. There is nothing missing.
Shanling M2s Specs
- Dimension:53mm×14.5mm×85.6mm
- Screen:3 inches retina HD screen(480X800)
- Weight:100 g
- D/A converter:AK4490EQ
- Gain compensation: High gain, Low gain
- Low pass filtering : MUSES8920
- Battery life: >9H
- Rated output level: 2.2VRMS@10KΩ
- Output power : 130mW@32Ω /12mW@300Ω
- Frequency response: 20Hz~20kHz(-0.2dB)
- THD+N : 0.003%(A-weighting,outputing 500mV)
- SNR : >108dB(A-weighting)
- Dynamic range: >108dB
- Output impedance : 4.8Ω
- Channel separation : >75dB(32Ω,1kHz)
- Capacity: 1800mAH lithium battery
- Playing hours : about 9--10 hours(3--4hours charging time)
- Sampling rate : up to 384kHz / 32 bit, DSD 128
M2X Specifications
- Screen: 3.2 inch touch screen with MTouch 2.0 system
- Dimensions: 98 x 60 x 16 mm
- Weight: 147 g
- Memory: Single micro SD card slot
- DAC: AKM AK4490EN
- Amp: 2 x AD8397
- Low-pass filter: TI OPA1612
- Decoding: PCM up to 32bit/384kHz, DSD up to DSD256
- Battery: 2400 mAh, fully charged in 2.5 hour
- Playback: 10.5 hours (SE), 7.5 hours (Bal)
- Output 3.5mm: 180mW(16Ω, high gain)/106mW(32Ω, low gain)
- Output 2.5mm: 212mW(16Ω, high gain)/120mW(32Ω, low gain)
- Output impedance: 1 Ohm (3.5mm), 2 Ohm (2.5mm)
- SNR: 117 dB (3.5mm), 116 dB (2.5mm)
- Channel separation: 70 dB (32 Ohm, 3.5mm), 107 dB (32 Ohm, 2.5mm)
- Bluetooth 4.2, two-way connection
- USB DAC function
Hi all... So I've been a happy Shanling M2s owner for a couple of years and it's time to replace it. I just went through all 26 pages of this thread and was surprised to find no comparison between the M2s and M2x, I'm not really sure why that's the case...? Is no one using the M2s anymore? o: It's a great player. In any event I'm trying to figure out how they compare. M2x specs show that its bigger, does it feel much bigger and heavier in the hand? I do like the nice small M2s size. How about sound quality comparison? I'm also wondering about power... is it more powerful, does it drive headphones better? (sorry I'm not sure of the right terminology here, power output? I use Etymotic ER4XR headphones, I think it can drive them well? but anyway I'm curious as I may get another pair).
I also wonder about how the M3s and M2x compare on the same criteria: size/feel, sound quality, power. I've read that the M3s is essentially an improved, larger version of the M2s. So I'm confused about which is the superior player, the M3s or the M2x. I do enjoy the UI of the M2s and I'm not sure how much I'd like the touchscreen of the M2x, but the interface has to be secondary to the sound quality (and size), so that's what I'm most concerned with.
Thank you for any thoughts!!
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
M2s had one of the warmer tuning we made and its output impedance of 5ohm wasn't ideal for some IEMs. M2X compared to it will sound more balanced, cleaner and more detailed, yet still having smoother presentation. And with lower impedance and better performing amp, it's fitting better to wider range of IEMs. But overall power is about the same.
Of course M2X brings completely different system, different controls, new features. And another important thing, MTouch in M2X is still being supported, with fixes, changes and addition of new features. While system in both M2s and M3s is pretty much dead, with no further development. (since we no longer work with previous software developer).
Hi,
I just ordered one!
Question - is there any way to move my playlist from my M2s to the M2x? I will use the same memory card with the same songs, so they would all be there.
I'm a reviewerr, but I have a question
Can M2X send digital signal to Mojo?
Also does it work with higher bitrates with Tidal?
I'm trying to get things to work for my review, and currently am unsure if I am even trying to do the right thing, as in, if it is supposed to do this
The main reason why you would want to use a balanced output is the added power and theoretical better management of noise (though sometimes balanced outputs are noisier than single-ended ones). The BLON BL03 are so easy to drive that even the usual single-ended output should be more than adequate. That's how I drive my BL03 anyway and I've had exactly zero issues.I've got a question for @Shanling or anyone who can answer. With these BLON 03 earphones,
https://www.amazon.com/HiFiHear-Earphone-Diaphragm-Headphone-Detachable/dp/B07TZ2NQCF
and the Shanling M2X
and this cable (or similar)...
https://www.linsoul.com/products/linsoul-hc-08
Would it be better to get the cord fitting the 2.5mm audio jack, or the 3.5mm audio jack? I believe that the 2.5 would would be "balanced", but to be honest I have never used a balanced cord before, and I don't know if it would be appropriate for the BLON and that cord or if it is even better. (I won't be using an amp, just the Shanling M2X).
Thank you to anyone who can help, and sorry for the newbie question.
