What's battery life in DSD 128? It will be nice if longer than 7 hours.
Shanling M2s Hi-Res DAP with AK4490 + MUSE8920, Bluetooth, & USB Out
- Thread starter nmatheis
Will the M2s come bundled with short USB-C to micro-USB OTG and USB-C to full-sized female USB OTG cables? This is super important for those that wish to use the device as both a standalone and transport
Only a long USB-C to USB charging cabble will be in the package,because all the customer need OTG cables and it will increase cost.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
it almost 8h,thx
And it just need a OTG plug.
around 8h,thx!
Can the M2 input power and output sound on USB at the same time?
What sort of cable/adapter is needed for this?
around 8h,thx!:etysmile:
That is great for it's size.When available in UK? Thank you.
hqssui
- Sep 29, 2014
Just a quick question- Does the volume control work if you are not in 'now playing screen'. For instance if I am browsing though the folders using the knob while a song is played, How can I change the volume?
Thanks
M2s can not input power and output sound on USB at the same time
Thanks
The volume control only works if you are in 'now playing screen',you can set "maximum volume limit" to avoid the volume became too loud
Btw,M2s has a play/pause button,you may stop the music while you are browsing though the folders.After you go back to the 'now playing screen',star to play the music.
hope it will help!
It will be soon,I will let you know once we are ready.
rockwell
- Dec 17, 2014
cool, this manufacturer is much more in touch with its fans and future customers than another one who openly admitted that it has no money and needs to rely on crowdfunding...
somewhere i read that the m2s doesn't sport a touch screen. is this correct?
Correct.
Man, I really love the M1 but this one looks even better for transport usage due to larger screen.
The Aliexpress listing mentioned 4.8Ohm, is that the output resistance?
M2s doesn't support touch screen but the stably OS we have developed for 4 years works quite quickly We believe M2s doesn't need a touch screen.
Yes,it is and it fits most of the headphones.
Total: 6 (members: 0, guests: 6)
