FrostyP
bluetooth at all says connection failedUps, seems colleague gave me older version, will fix it ASAP.
And can't connect to iPhone in which way, as BT receiver, HiBy Link, USB DAC, USB OTG?
Please try Winrar
Please try Winrar
New functions:
1. Added setting of wheel sensitivity (4 most sensitive, 1 least sensitive)
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
I think this is the best we will be able to get with current software development.
Would it be possible to lower the minimum sensitivity even more? I'm still moving two lines fairly often when I'm trying to move one. It's better than it was before, though. Thank you for (partly) fixing the scroll wheel.
Lately I buyed new bluetooth EarPods from SoundPEAT - they support BT5.0
I wanted to use them together with my M2s - but I've problems with them (actually the player has problems with them )...
I can pair them - no problem.
But when I start playing music, the players tells me, that the current title's format is not supported and switches to the next song - and tells the same again and switches to the next and the next, and the next and the next....
If I'm lucky, I'm able to manually stop the playing - but it also occurs that I had to switch off the device...
When I then connect a normal cable based headphone everything is fine and it plays all the songs about which it says "unsupported" before...
Any idea what's going on? And how I can resolve this issue?
(or even how I can get a logging about what happened)
BTW, I still use M2s firmware 3.30
Here is a link to the EarPods at Amazon: https://www.amazon.com/SoundPEATS-W...=8-8&keywords=soundpeats+bluetooth+headphones
I have a shanling m2s and I saw that it has an output impedance of 4.8 ohms ... can it be a problem using it with a couple of iem with 25 ohms like the kz es4?
ThisDifferent IEMs react differently to the output impedance. Pretty much you need to find chart showing "impedance reactivity" to judge it more.
This
Hi Shanling. Does the M2s provide a 'true' Line Out capability. i.e., bypassing the headphone amp, or is it just the headphone amp output fixed at max volume? Thanks.
