headwhacker
- Sep 4, 2013
what is the diff between cowon plenue d and m1 ?
Sorry have not heard the plenue yet.
gr8,
i jus hope its loud enough n with no hissss.
thanks !
I'm sending a well-known headfi buddy the M1 to audition soon because he's not satisfied with Plenue D if that days anything...
A headfi buddy I play a high level of trust in is driving Senn HD600 straight out of M1 and is quite impressed with how good it sounds. At 15 Ohm impedance and 119 dB/mW sensitivity, it doesn't look like Roxanne is very hard to drive, certainly should be easier than HD600. And M1's output impedance is less than 1 Ohm, so you don't need to worry about the M1 altering Roxanne's FR. Hope that helps...
Not only the M1 drives the HD650 pretty well as it almost does the job for the K701. Quite impressive.
I just tried it on my M1, it is loud enough but don't think it can "drive" HD650. It is very thin, no depth, no body.
EDIT: Eliminated the X1 due to overwhelming complaints online about poor UI and slow processing/library scanning. Thanks!
If I don't use the M1's DAC function and DSD support which is better?
I noticed Fiio X1 2nd Gen has a low pass filter (does that help?) and other than higher output impedance actually the other specs appear to be better than the M1....
I'm in a dilemma as I don't want to change too soon and now both are roughly the same price from China (actually the X1 is cheaper by a little)
Shanling M1:
- Output power: 35mW@32ohm
- Frequency response: 20Hz--20kHz(-0.5dB)
- THD+N: 0.006%(A-weighting,outputing 500mV)
- SNR: >105dB(A-weighting)
- Dynamic range: >105dB
- Output impedance: 0.1Ω
- Channel separation: >70dB(32Ω,1kHz)
- Referenced clock jitter: 200 femtosencond
- Dimensions 60mm×50mm×12.8mm
Fiio X1 2nd Gen:
Partial Performance Parameters for Line Output
THD+N ≤ 0.003% (1 kHz)
SNR ≥115 dB (A-weighted)
Frequency Response 5 Hz~60 kHz (-3dB)
Dynamic range ≥107 dB
Crosstalk ≥ 101 dB (10 KΩ/1 kHz)
Line output Level 1.7 Vrms (10 KΩ/1 kHz)
Partial Performance Parameters for Headphone Output
Output Power 1 > 100 mW (16 Ω/THD+N<1%) Output Power 2 ≥ 70 mW (32 Ω/THD+N<1%) Output Power 3 ≥ 8 mW (300 Ω/THD+N<1%)
Output Impedance <1Ω(32Ω loaded)
Crosstalk ≥72 dB (1 kHz)
SNR ≥113 dB (A-weighted)
MAX output current >130 mA(For reference)
MAX output voltage >4.0 Vp-p
Dimensions 97mm×55.5mm×12mm
Actually that's not saying very much because you haven't specified what makes him unsatisfied with the Plenue D. Furthermore the comparison is pending and there aren't any conclusions and final thoughts on the differences between the products.
On face value, I will say X1-II spec is, at least to me, a little better than M1. But subjectively speaking, I'll say they both sound pretty similar in overall SQ to my ears. That is, they are both in the entry level of audiophile DAP market.
As for stability - besides that library does scan slower on X1-II (though it isn't so slow that I can't live with it), I'll say that both X1-II and M1 are more than stable enough for music playback in general, but they both have bugs that need to be fixed. I won't say one is in any significant way worst than the other.
[color=rgb(33, 33, 33)] I was willing to buy jaybird x3 and wanted to know if anyone has used with M1[/color]
Hi
Code:[color=rgb(33,33,33)] I was willing to buy jaybird x3 and wanted to know if anyone has used with M1 [/color]
