dimmockg
- Sep 10, 2007
@focalor.... thankyou
anybody have experience of the m1 with fiio e17k?
ok cheers, not mucb point in the e17k then or it wont add much to the rig
oppo ha2 or mojo then???
Hello guys,
Just sold my iPod Classic 7th gen, while it still holds it's value. Now searching for a new DAP. I'm considering the Shanling M1 or the Fiio X1 II. I've done a fair bit of reading of this thread and was wondering if there were a few things you could help me out with.
I don't really have the money to spend on a Mojo or other DAC, but I do have an amplifier that I would like to pair with my new DAP. The amp I have only has 3.5mm inputs and outputs. Here are a few questions:
1. With the amp I plan to use, would the Fiio X1 II be better, as it has a line out which can be plugged into my amp to prevent double-amping?
2. I was also thinking I could use a USB C to 3.5mm from the Shanling M1, which would allow me to plug in my amp. Would this work and would it be better than using the headphone out of the Shanling M1?
I hope that makes sense, any help would be much appreciated!
Generally I'd say that the M1 sounds quite good on its own and I don't really see any point in pairing it with sub $100 amp/dac combos, all you achieve is to carry around more weight
Just my 2c.....
I've quoted my post from the previous page. I've been considering this DAP along with the Fiio X1 II and want to know how it's standalone performance is. I may pair this with an amp that I have, but I imagine I will also be using it by itself on the go. In this case, would you say there will be a noticeable difference in between the M1 and X1? Also will the X1 with a line output provide better quality sound than the headphone out of the M1?
I'm sorry I've not heard the X1. Only reason to add an amp to the M1 would be if you're planning to use pretty hard to drive headphones with it. What headphones are you planning to use it with?
I'll see how i find the m1 first, but knowing me i will end up getting an amp/dac combo
If i went for say a opus, oppo or mojo am i correct in thinking it is this cable:
http://penonaudio.com/OTG-Pure-Silver-Cable
Or to change sound signature or for more refined sound. For instance, I find M1 sounds pretty good as a super-portable standalone DAP, but add Mojo and it makes for a very nice transportable stack!
@nmatheis
is the sound signature between M1 to M2 quite a jump ?
Ignoring price, which one do you prefer for SQ ?
