stev121314
- Jan 28, 2014
would you guys reccomend this, XDuuo X3, FiiO X1 V2, etc? or anything else around this price point
Is there a way to make it play the last song on startup? Its a pain having to select files each time I turn the M1 on.
what is your requirement?
Yes. Can't answer your question unless you help with more specifics @Clericlaw.
Want something that can play music and sounds the best... has a good UI too and can skip songs without going onto the screen
"Sounds the best" is too vague, bro. What type of sound do you like? Warm? Cool? What are you driving? IEM? Full-size cans?
I made a video of the UI. Go to my YouTube channel. It's linked in my signature. You can see if the UI suits you.
Yes, you can change volume, play/pause, skip songs with the screen off.
I don't even know what sound I like, but I like to hear more detail and less congestion (like instruments being muddled) - currently driving Full Size cans..
What would be good
What's your budget? I'm thinking something like the Shanling M2 might be a better choice for you.
a bit too expensive, around a 100 is probably my budget
