Just got mine and loving it as a transport for my mojo with the L2 cable.
Unfortunately however the LDAC receiver functionality seems a little problematic when I try and connect it to my Sony HT-XT3 soundbase. It will establish a connection and show that it’s using LDAC but I just hear white noise from the output on the M0. The XT3 is fairly old and one of the first Sony devices to support LDAC tx so I wonder if the incompatibility is related to that. I struggled to get my A15 Walkman to connect over BT at all. Maybe it’s a more fundamental Bluetooth issue with older devices?
I understand it’s a brand new feature in the 2.0 firmware and I’m happy to provide additional info to help diagnose the issue. If Sony are providing the reference implementation it might be worth finding out if they know of any compatibility issues.
My MDR-1ABT and WH-1000XM2 headphones work perfectly with the transmitter functionality of the M0 though
Found my first problem. But not sure of it is the dap or my fault. I got Stevie Ray Vaughn in 2.8 dsd and put it on all my players. All of them seemed to work fine except the M0. It plays ok but for some reason it did not recognize the album name or artwork. So it is under unknown.
Is there a way to make the m0 work with a Bluetooth controller? I bought the fiio rm1 which worked with the m2s but not the m0. It pair up but doesn't respond to anything. I just need to skip tracks with it dones i use it in the car.. It's hard to do it via the player
Hello Shanling. Did you or will you implement LDAC in receiver mode while using USB OTG functionality via firmware update? Use case: Android Oreo Smartphone -> LDAC -> M0 -> USB OTG Cable -> Chord Mojo -> Earphones
In receiver mode LDAC is supported (In addition to SBC and AAC). Not sure if USB audio out is supported when in receiver mode. Will check and report back.
