- Jan 15, 2015
What USB-C -> micro-USB cable are you using? Where did you get it?Btw pairs well with my mojo.
Thanks.
M0 is nice for its price. Sound is good but not as good as mojo. Im bad at describing but for me mojo is much better and more details than M0. Well i think it just matter of taste. Like i saw some said that Hugo 2 isn't worth for it price cus its just better than mojo a bitI have the opposite problem. It's too large. Width and height are fine, but I'd like version 2 to be thinner. Thanks @Shanling
Quick survey question for Chord owners... Do you really find the Mojo that much better for sound quality? Not wanting to start any flame wars here, but I was never that impressed with the Mojo. I love my Hugo 2, but the differences in SQ between it and the M0 are much, much smaller than I expected. I doubt I'd be able to tell the difference unless I was in a perfectly quiet environment. To have a DAP this good and this small - is it really worth carrying a Mojo as well?!
https://shop.musicteck.com/products/shanling-l2-type-c-to-micro-usb-audio-cableWhat USB-C -> micro-USB cable are you using? Where did you get it?
Thanks.
You might need to turn it on via the developer options.hi guys. not sure why but when i connect my phone to my m0, it only says bt connected. my phone is running oreo and it has this LDAC support. i dont know what im doing wrong but i have yet to try connecting my m0 to my sony xb30 which is a bt speaker also with ldac capability. any inputs is highly appreciated.
This link might help
https://www.google.com/url?sa=t&source=web&rct=j&url=#&ved=0ahUKEwiYiqrW5szbAhVjzlkKHaR-BX0QwqsBCDQwAQ&usg=AOvVaw0VTJzWxrN8ZFOD4xbU2nov
Hmmm, I read somewhere in this post that some people are having issues with LDAC.it is actually on. tried to toggle it from sbc aptx ldac but still remains to bt connected. will check the link you posted and by the way my phone is a oneplus 5t
also did but no success.Hmmm, I read somewhere in this post that some people are having issues with LDAC.
Have you tried toggling it on the M0 too?
Hmmm, not sure what else to try. Might be the something specifics to the 1+ 5t. I'm using an Essential PH-1 on 8.1 myself.also did but no success.
You don't need to change anything in the M0's settings if the M0 is the receiver. In your phone's BT settings, click on the wheel next to the connected BT device (M0). My phone (an LG V30) has the choice of "Most Stable" (AAC) or "Best Audio Quality" (LDAC).it is actually on. tried to toggle it from sbc aptx ldac but still remains to bt connected. will check the link you posted and by the way my phone is a oneplus 5t
I just test LDAC receiver mode with Sony NW-A46 But I can't pair both together, can't even find each other devices (open BT function of both devices and find, but nothing found).
If someone use similar combination (Sony DAP+M0), please suggest me proper way to use them together.
Doesn't pair up with WM1Z either. It has something to do with limitation of Sony daps. Have no idea what; no issues with smartphones supporting LDAC as everybody else reported successful pair up, while Sony daps are not happy.
Since FW 2.0 the connection with a Mac works though it is SBC only. Couldn't succeed to connect it with Apt-X or AAC, not even by forcing the Mac to use Apt-x.
What I meant is lets say if I click on all music to browse all my songs. Will it sort the songs based on what is written in the file's metadata? Or does it sort based on the file name of the music file? For instance in the metadata my song title is Country Road. But the file name of that song is 01 - Country Road.flac
Will the player sort it as "01 - Country Road.flac" or will it just show Country Road? Because every other chinese made DAP out there will just list it as "01 - Country Road.flac"
What a nice device. Only complain is that its too small, its hard to hold lolz. Btw pairs well with my mojo.
Anyone using the M0 as a bluetooth dongle receiver via LG V20? As of FW2.0 update, BT no longer outputs sound via V20.
Apart from that, really liking the way the M0 sounds (when playing flac directly off SD).
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Still looking into this. Seems Sony added some BT device filtering, where it ignores any phones and players and just shows headphones and speakers.
Receiver mode doesn't support aptX, please try to force your Mac to AAC.
In open all, it shows songs organized by the song title, not file name.
So for your example, it will show up as Country road,
My advice is, put it in your pocket
Can you please check in developer options, which codec is being used? When you connect M0, which codec is displayed on screen of M0?
