I also installed 2.0 firmware without problem.
LDAC works flawless.
Thanks. I just tried again with a fresh download to desktop and then trying to unpack with RAR Opener.Hi Mike did you open the file on your desktop? I had to download and then open before finding the update.bin file.
Cool, hope it works it was a little distracting as my SS card is exfat not fat32 and Android doesn't like exfat or NTFS formatting. LolThanks.
I searched up RAR and realized this is like ZIP.
I was connected to a work computer that I couldn't put new programs on.
Switched to my MS Surface Book Win OS 10 and downloaded RAR Opener.
I tried to unpack on the micro SD card and got an error message.
I re-downloaded from the Google link and still got the error:
"Error opening the archive (check available disk space, that you have a valid password, or that the archive is not damaged or partial)"
Will keep playing with it.
Mike
My card is exFAT.Cool, hope it works it was a little distracting as my SS card is exfat not fat32 and Android doesn't like exfat or NTFS formatting. Lol
My card is exFAT.
Music was working on it, so I didn't think about it.
I guess I need to find another card or transfer music off it and reformat.
Thanks for troubleshooting.
Will try something.
Although doesn't explain error unpacking it to desktop?
Mike
Thanks.So the way I did it was to download a fresh file directly tot he Android device. Then unpack the file and upload the update.bin file to Google drive. Then I used my Chromebook to transfer from Google drive to the memory card I used on my M0. Then ran the update on the M0 and it worked.
Try switching the Chromebook and Google drive for your surface and any cloud service respectively. I troubleshoot random IT problems on mobile devices all the time and this is something I've had to do in the past. I can't explain why the file won't unpack on your surface or Android device (minus using the RAR app) but I can tell you if you're like me you want to get it working no matter how stupid the process is. Lol
Just search for FAT32Format.Thanks.
Music transferred off card.
My only Win 10 OS based format options are exFAT (Default) or NTFS.
I don't see a way to format micro SD from the M0 in System.
Another format program?
Mike
Thanks.
Hmm.Maybe your card is too big? FAT32 was designed for smaller capacity storage, and you can't make a single FAT32 partition larger than 32 GB.
Try different filters, for Flc8 i am using apodizing fast.Got my M0 yesterday.
I'm very surprised this little device has such decent/good ouput.
Paired it up with my ie800 and W80 and they both sounded great. Seems like mids are a bit smooth out compared to my V30 and WM1A though. Clarity isn't there yet...and bass very punchy.
Not bad for $99![]()
Hmm.
I have a 256 GB card.
I transferred all the music off and I am (slowly) formatting with Windows command line format /FS:FAST32 D:
If:
- only 32 GB available, that woudn't be good
- if above, then how do you upload new firmware? Exchange exFAT music >32 GB (eg what everyone has) mSD with a different FAT32 formatted mSD?
Why not make DAPs that work with the newer (eg modern) exFAT file system.
I'm sure I'm missing something, but this seems very tedious.
Mike
Great! Will try this tonight.Try different filters, for Flc8 i am using apodizing fast.
