I started to write a short first impression, and it grew into my usual "twister6" detailed multi-page review. So, HERE it is, full detailed write up about Shanling M0. Enjoy it!
@Shanling my m0 does not play music when connecting to my smsl AD18 trough BT, they both look like they're paired and AD18 even shows sampling rate and with signal but no music comes out, can it be a FW trouble? i use smsl AD18 everyday with BT and many devices and i haven't had any single problem.
Since M0 has clock function. Is it possible to has clock mode like smartwatch?
One more question, if HibyLink like application has been developed, is it possible to use like this, pair BT headphone with M0 and control M0 via smartphone with app?
Just added a little update with Line Out test results (paired up with E12A, updated Wired/Wireless section of the review, on the last page). Makes me wonder, since ESS DAC combines amp stage, if they actually bypass the amp to have a direct DAC output, instead of just raising volume up to the max. Either way, output is very clean, transparent, and no clipping.
Oh wow! I have just received, charged, loaded and linked my M0 to my Chord Hugo via USB, I am now listening through my Monk Plus buds and I am completely blown away, this little
device punches well above it's weight.
I can cope with the USB cut outs at the moment as I run through my review cycle, but I am eagerly awaiting the 1.52 update that stabilises USB output.
Congratulations to Shanling and to everyone who has had the good taste to pre-order one!
Having a hard time burning my M0 in. It's either locking up or powering down on me.
The only power setting left on right now is Idle Mode @ 1min. But since the M0 is playing files all night long, it's certainly not Idle. What's going on?
I have my pink noise track on repeat loop. Is this just a bug?
Here is how I have it set now while running battery test: Sleep timer off, Idle (auto-standby on, auto-shutdown off), screen off - 40s, Play mode on Repeat track. Have it on high gain, playing mp3 track on repeat with IEMs connected, at moderate listening volume. Got 12hrs on a single charge run, but it's not the best case scenario low gain/screen off type of test, since I had it on high gain, playing with settings, using LO with amp, and going back'n'forth between a few flac tracks as well. Will run a fresh battery test with a next full charge.
