HiFlight
My M0 and case has been shipped. Hopefully it will arrive first part of next week. Looking forward to comparing overall performance to that of my M1.
Well, it powers the hard-to-drive e5000 by Final Audio... so that's good!
And sounds pretty good, too.
The Sony headphone has ldac and so does the M0. This is BT so no cable needed. I was hoping the M0 could grab the music from the iPhone and the headphone could connect to the M0 so I could have ldac instead of aac codec the iPhone uses.
Can’t be done and I understand.
Agree, "wire" M0 to your smartphone/dap source and pair up with LDAC enabled headphones (if you want to stream apps from your source). But I think due to a lack of more LDAC enabled wireless headphones (anybody else besides Sony and upcoming Fiio cans supports it?) and more LDAC enabled sources - M0 can convert any wired pair of headphones/iems into LDAC wireless one.
THE POWER OF MUSIC COMPELS YOU!!!
Would be nice, at least that's what I'm hoping for, but will see. Right now I hope to be able to pair up M0 with WM1Z using LDAC, wihch is not possible yet.
Probably just for fun, or to compare the SQ when sound bypass different units.What's the point of doing that?
I think the real confusion is that people want to use the M0 as a transmitter/receiver at the same time to leverage the LDAC capabilities of the M0. iOS obviously only supports AAC and Android will not be introducing support for LDAC until Android 8.x + the manufacturer allowing/using it on their fork of Android.
I understand that most people want to use LDAC but want to use it to stream from the phone to the M0 then to an LDAC enabled headset. What I see Shanling saying is that you can't do that because of the limitations of the Bluetooth on the M0 (or in general). i.e. it can't be used to transmit/receive BT at the same time. The easy work around is to connect the M0 in DAC mode via cable then Bluetooth (LDAC) out to the headset. @Shanling, correct me if I'm wrong as I've seen the question asked multiple times and this might serve to explain (if I'm correct).
How does this compare with the M3s sound wise? Can someone be kind enough to do a comparison between the two players?
Does the M0 still have the same 15,000 file limit as previous M version DAPs ? if so , will this be addressed in the future?
Back in March, there was talk of audio book and podcast support, specifically bookmarking and speed controls. Now that the device is real, and firmware is up to v1.5, how's that going?
@Shanling , Frankie, one big request. It would be awesome to have playback buttons and scroll bar on one screen, instead of swiping to the next screen every time you want to fast forward the song. So, can you please ask Hiby to combine it in the next FW release?
Also, in the playback screen, instead of swiping left to get to 2nd screen with song info, add to playlist and music setting and then another swipe to lyrics window - can you swipe up/down to get to those windows? If you put fast forward scroll bar on the main screen, just to eliminate error of swiping screen left/right vs fast forward/back, it will make sense to swipe up/down to get to other screens. I noticed, up/down swiping is not implemented in the touch screen interface yet, so would be a good idea. I do like ability to assign a short cut to double click on volume wheel (works great for play/pause) and long press on display to get to the main menu. But I would LOVE to have playback button controls and scrolling through a song on the same screen, PLEASE!!!
Not very responsive?
Thnx my friend, I will wait to see if they tweak the firmware. Like I said not that I need it, plus the Shanling I had used the scroll wheel and hardware buttons (m2) and It worked pretty good (no touch screen).
I was wondering if there was any guide on how to set it up as an external DAC/AMP on windows 10. I tried using the monitor and digital outputs for the playback devices, but I can't get any sound to come out from things I play on my PC. I changed the usb mode to dac, plugged it into the pc, and the screen on the m0 though says it is in dac mode and outputting in 24 bit 48khz...but I don't know where to go from there.
Edit: Just read in instructions you need a driver installed first...is it the same for android?
Also - in the instructions it says avoid using while charging...but it charges when in DAC mode connected to the pc...does this damage the device?
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
