shahrul5689
a limitation i guess...well, i'll play via bluetooth mode as a resort, tq for the reply though @ShanlingThere is no way how to prevent them from charging.
Looks like the M0 snow crashedAnyone seen this before?
Oh also @Shanling, is there a way on the m0 to jump to the album and/or artist for the currently playing track?
If I had to guess, you'd tap the artist or album name in the track info screen? Could someone who owns an m0 try perhaps?
Thanks
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Hi,
I can not change the volume level with using any methods(with wheel or ui). Default volume is stuck on 20. Firmware is v3.6. Is there anyone that experience this issue?
So, do you believe it started after updating it to the V3.6? (released in September)? Or out of nowhere it started misbehaving?The software is getting increasingly buggy.
The player used to update the files list every time that I unplugged from a pc but this only happens rarely now.
Resume hardly ever works properly now and mostly starts from an earlier place or even a different track.
It was all fine until a couple of months ago.
Factory reset doesn't help.
I'm on 3.6 as well.
It's still current hardware but the software hasn't been updated for ages.
thanks for getting back to me so quickly.So, do you believe it started after updating it to the V3.6? (released in September)? Or out of nowhere it started misbehaving?
For update, do you have the automatic update enabled?
Unfortunately it didn't work.Please did you tried factory reset?
Do you have USB volume set to fixed or variable in the menu?Hello, so I had tried using a dragonfly red in the past with the m0 but it didn't work and I was told it was because the m0 didn't have enough power to power the dragonfly.
I recently tried again and it worked but there doesn't seem to be anyway to control volume.
Does anyone know a solution to this?
