Shanling M0 - Smallest Hi-Res Portable Player - New Firmware V3.6
Jun 4, 2019 at 11:23 PM Post #5,281 of 6,446
On the Shanling website the v3.0 firmware link states that the release date was 15th Oct 2018. Is this the latest? Thanks.
Jun 4, 2019 at 11:35 PM Post #5,282 of 6,446
yeah i had to go back to 2.5 just for the party EQ =( I will be patient.
Jun 5, 2019 at 1:39 AM Post #5,283 of 6,446
This is what I see.
15th october is date for USB Driver.
Jun 5, 2019 at 2:08 AM Post #5,284 of 6,446
This is what I see.
Somehow the dates are reversed when I look at your website whether on my computer or in the case of the attached screenshot, my iPhone.
Jun 5, 2019 at 2:26 AM Post #5,285 of 6,446
So apparently software team felt there were too many Presets and so they deleted two of them, one of them being Party.
Meanwhile I got from them setting for Party preset, which is quite simple.
0.0,0.0,-4.1,-4.1,-4.1,-4.1,-4.1,-4.1,0.0,0.0
So anything from 125Hz to 4kHz should go down by 2/3.
Thanks for info. Our website on mobile has many problems, so will add this as another one to fix.
Jun 5, 2019 at 5:36 AM Post #5,287 of 6,446
Gotta say, I really like the newest firmware update. Never found the M0 sluggish, but the changes have made it even faster. Overall just a neater, cleaner look and a bit more functional. Also like the new EQ and custom EQ profiles. That's something that often stops me from using EQ because I hate having to edit it when I switch earphones. Overall a great update. Awesome stuff @Shanling !
What are these pretty headphones?
Jun 5, 2019 at 5:42 AM Post #5,288 of 6,446
Hi, since we are talking about web bugs, when I click on "M0 Manual" (on desktop), it downloads "M0 Manual.pdf" file, but it has "Shanling M0 Firmware 2.3 notes" inside.
Thanks
If anybody see any problem on website, you can just PM me, no need to put more noise in this thread. ;)
Jun 5, 2019 at 6:52 AM Post #5,290 of 6,446
Would you happen to have the presets for sharp. It is missing as well and really helped clean up some of my muddier iems.
Jun 5, 2019 at 12:09 PM Post #5,291 of 6,446
I have this issue, when connected via bluetooth to computer, device would disconnect for no apparent reason or start to act like it was having reception issues(music lagging etc) with older firmware i had no such issues. Shame since i really like new ui and improved speed of everything not to mention finally it has lower latency.
Jun 6, 2019 at 1:49 AM Post #5,292 of 6,446
Sharp should be
-6.0,-6.0,-6.0,-5.5,-4.2,-3.6,-1.8,-1.2,0.0,-1.2
And if anybody is missing reggae
-3.5,-3.5,-3.5,-0.6,-3.5,0.0,0.0,-3.5,-3.5,-3.5
Will report this to software team to check.
Jun 6, 2019 at 2:16 AM Post #5,293 of 6,446
Sharp should be
Thanks for sharing these. Would be great to see the values while adjusting them. I can't even see the handle through my fingertip. :)
Maybe a dev could place the value of the frequency variable on the screen when moving the handle. I think the scale on the left could be a good location for that.
Anyway, thanks for the customizable EQ.
-edit-
fixed some typos etc.
Jun 7, 2019 at 3:04 AM Post #5,294 of 6,446
Maybe i'm missing something, but how do i set this under custom? When i go to EQ>Custom>Edit on M0 there are no numbers like this, just a bar for db. My fingers are not even big and i have trouble setting them in place. Honestly I cant see how this would be difficult to undo. Please ask them to put the old presets back. As a suggestion maybe there's a way to code where we can use the volume rocker to move the eq bars and as mentioned earlier something showing which db level is set. I really liked that they put a custom option, but on a screen this small its difficult to use. Maybe even add a EQ setting application/file we can tweak on a bigger device, like PC and sync. Just some food for thought.
Jun 7, 2019 at 6:20 AM Post #5,295 of 6,446
