Any general timeline for when we can order the stainless steel clip for the M0? It has said coming soon for a few weeks now.
Shanling M0 - Smallest Hi-Res Portable Player - New Firmware V3.6
- Thread starter Shanling
- Tags
- dap ldac shanling shanling m0
Also, the official Shanling forum doesn't work at all. It returns a SQL error for the past 2+ months now.
http://discuz.shanling.com/
That was just first idea in march, changed to all plastic case since then. You can find explanation of such change about 150 pages ago.
That forum is out for long time.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Try eBay.Any general timeline for when we can order the stainless steel clip for the M0? It has said coming soon for a few weeks now.
21qz
- Mar 10, 2011
We
steel clip? Plz shareAny general timeline for when we can order the stainless steel clip for the M0? It has said coming soon for a few weeks now.
We
Plz read my post above.
One note to everybody: I'm on vacation next week, so no chatting with you guys until 17th December.
cirodts
- Jan 27, 2016
someone has compared the r3-mojo with m0-mojo which combo sounds better according to you in coaxial too.
We
http://shanling.com/Images/KE/M0/M0 instruction1/18.jpg
So Shanling used to have a Stainless clip, hasn't updated the website to show that it was available and then discontinued it and only sells a plastic only clip but also has not added that to the cart? Is that correct?
Can you either redirect it here or take it down then? It was very confusing when I was doing research to buy the M0 because I kept waiting for what I thought was the main forum to come back online.
Looks like the all plastic one was made to address problems with the metal / plastic hybrid ones? It at least uses a amorphous thermoplastic polyamide, looks to be Grilamid TR90? If so, it's a Nylon 12 (Polyamide) product.
The TR90 series has a higher flexural fatigue strength and UV resistance. Looks like the case uses a cycloaliphatic grade.
So it's actually fairly well made overall, similar to how the M0 is aluminum not plastic and the surface is hardened, not plastic.
But maybe go ahead and update the product page that suggests that the metal clip is coming soon when it has already been discontinued?
unfunk
- Jun 27, 2012
Does anyone know a quick workaround to the m0 defaulting to AAC over LDAC in receiver mode?
I have to manually change it from my smartphone to LDAC. Its quite the annoyance since I have to do it each time I connect.
Edit nvm, just solved it.
In case it helps anyone, I am using a galaxy s8. You just have to turn LDAC on from the "SmartThings" notification that appears when the device is connected.
myliferockkss
- Apr 18, 2016
You can try this too... power on the BT first on M0 and later power on the BT on phone....this will directly show LDACDoes anyone know a quick workaround to the m0 defaulting to AAC over LDAC in receiver mode?
If you do other way around than it will show SBC/AAC
greatwhite58
It depends on wether you like the Mojo as that is what sets the sound signature in both cases.someone has compared the r3-mojo with m0-mojo which combo sounds better according to you in coaxial too.
ninetylol
- Jan 14, 2017
EDIT: just got my answer 2 pages back. What a shame it doesnt work :S Why is there no LDAC on PC when every crappy smartphone can do it...
Hey got a question regarding the Shanling M0 as a PC DAC.
Can i connect the M0 on Windows 10 as a USB DAC and use it as a bluetooth dongle streaming in LDAC to my Sony WH-1000XM3?
Since there is no LDAC (or even aptX-HD) bluetooth dongle yet this would solve all my problems!
Thanks in advance!
Thanks in advance!
endgame4
Why is there no LDAC on PC when every ****ty smartphone can do it...
licensing. no, you can not do what you want with the M0.
Total: 21 (members: 0, guests: 21)
