Disregard what's below, I've updated to FW2.2.
Hadn't seen it published since I've been monitoring the title of this thread, which still reports 2.1.
However, the battery indicator you'd promised is still missing.
Hi, Shanling.
I've been using my M0 via USB audio output with Windows 8.1
I play videos that I frequently pause and rewind, mostly for transcription; VLC player.
I also play music; foobar2000.
There is a problem. The video starts with no audio delay, but after a few pauses or rewinds,
there is a noticable audio delay, sometimes up to a few seconds.
I disconnect the M0 from the cable, reconnect, and it's back to zero.
I've changed the USB Streaming Mode to a number of different options with no effect;
it's currently at Low Latency, which gives me the same results as Minimum Latency.
I've tried changing ASIO Buffer Size but it has no effect, and I'm not using ASIO output on either player anyway.
I experience none of the above problems when I stream over Bluetooth.
Or maybe I do but it's not noticeable.
Do you currently have a fix for this?
Are you aware of this problem?
Will you be issuing a fix for this?
Thank you.
