I'll try that but it may take some time for a 512gb card , thanks!Many problem occur when copying from your computer to the micro SD card.... I had the same problem as you but after creating directories for each album and playlist directory on thy sd card and then for each folder copy files into it folder by folder solved my problem with my 128 GB sandisk extreme micro sd card. I failed when I tried to copy over many folders in one go. ....
Shanling M0 Pro - Ultra-Portable Hi-Fi Player, Now With Balanced Output!
- Thread starter Shanling
Before you go this strange (and tedious) route, check your files: structure, names, album art size, tags, etc.
MalinYamato
yes, it is tedious and I wish there were better ways. In my very tedious way I create folders for every album and then for each folder select all songs in the folder on the disk and copy them over in one go, but for me to merely select the root folder and copy that to the sd card however successfully copied 75% of all the files, the rest did not show up when doing scan on M0 Pro.Before you go this strange (and tedious) route, check your files: structure, names, album art size, tags, etc.
Note, when I check all the files that I copied the easy lazy way all the files are visible on the sd card on the computer and look OK but when transferring the sd card to M0 Pro 25% are missing.
I do everything on a Linux Ubuntu 22.04 computer Intel i7 13700K 12 cores, 64 GB DDR5 mem, 1 TB of Samsung 980 Pro Nvme m.2.
sd card
There is. Insert the card and enjoy
Disclaimer: Data is complete and tagged properly.
thanks for the replies guys... I will try that but it may take a long time because the write speed that way is very slow
I've just tried copying a few of the problematic files with the card inside the M3 in storage mode and the problem still persists =( .. i give up. I'll try to manage those files browsing by folders or playlists
MalinYamato
deleted as I found the prob.
MalinYamato
I think I found one reason why M0 Pro cannot not find files that are copied by various copy utilities on your computer into the sd card. Filename or folder-name that contains blanks at the beginning or end such as this one ' My love for you ' appears to confuses M0 Pro and thus fail to scan and read. As a result you cannot find the files on your M0 Pro.
Request to Shanling> can you confirm with your engineering team if their scanning program fails when the filename or foldername begins or ends with a blank ' ' ? If so you may enhance the scanning program to deal with the exception.
To see how really filenames and filenames are spelled you have to go into command-line mode.
Below I am inside my sd cards folder. There you may see many files that starts and ends with a ' which is OK but the files that has a blank before or after the ' character fails to be recognized.
A workaround is to rename ' My love for you ' to 'My love for you' -- something that you should not need to do manually as you may write an easy python script to do the work before you issue the copy command, to copy all the files over to the sd card in one-go.
MalinYamato
SOLVEDI think I found one reason why M0 Pro cannot not find files that are copied by various copy utilities on your computer into the sd card. Filename or folder-name that contains blanks at the beginning or end such as this one ' My love for you.flac ' appears to confuses M0 Pro and thus fail to scan and read. As a result you cannot find the files on your M0 Pro.
A workaround is to rename ' My love for you.flac ' to 'My love for you.flac' -- something that you should not need to do manually as you may write an easy python script to do the work before you issue the copy command, to copy all the files over to the sd card in one-go.
this solves scanning issues and removes possible "files do not exist" or "unable to play file" on your M0 Pro. I have verified the method and it solves all my problems.
On Linux and perhaps also on Mac, run my program stripper.py as follows. It is very fast and the fasted way to copy files is to use rsync in progress mode.
- stripper.py <top location of all your files>
- rsync -arP <top location of all your files> <your sd card>
I have both the M0 and the M0 Pro and I have never had the problems you are solving for yourself.SOLVED
program available at: https://github.com/MalinYamato/stripper
MalinYamato
You are lucky not having filenames or folders with a leading or ending blank character... When I download and convert from Tidal some filenames and folder names have a blank in the beginning or at the end or both.I have both the M0 and the M0 Pro and I have never had the problems you are solving for yourself.
Ok, reported, but I don't think I ever saw any user having such issue, not even sure how would you end up with blank spaces in front of the file names
You are lucky not having filenames or folders with a leading or ending blank character... When I download and convert from Tidal some filenames and folder names have a blank in the beginning or at the end or both. M0 Pro is unable to handle that.
For fun, you may insert a blank at the beginning and end of the filename of one of your files or folders to see what happens.
Downloading files from Tidal?
Thanks for the reply, The new scan shows all files on the 512gb card, 12.077 that includes all files, The new scan doesn't seem to skip any files. The scan detects all files but then a lot of them are missing. Even when I hit the "unknown artist" there is a list of all the albums missing, but when I click on the album , the album is empty.
Something strange is that most missing albums are from 2 specific artists that I have a lot of tracks, singles remixes albums etc.
For these two artists A and B I have 1.283 and 924 tracks on card. When I open all tracks for these artists I only get 987 and 610 track for each. All tracks a properly tagged and album artists tag. The are some other albums missing for different artists and compilation. I tried putting these files on a 128gb card with nothing else and the problems persists... so maybe the problem too many tracks for a single artists?
If your issue is present mainly on one section of files, it might be best to check the tags on them.
You can send us some sample for a test if you wish.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
There are many way to get tidal fileDownloading files from Tidal?
MalinYamato
yuppers! without that a M0 pro would be much less valuable. I write my own python program to do that including an instance of decryption using AES chiffer algorithm and special MQA file format handling. I will merge stripper.py with my download-decrypt program to assure that all I download have not blanks at the beginning or end. As you really know, there are very expensive windows programs to do that which are extremely slow and their their MQA handling is not that great as they try to compress into smaller files. I dont care so much for large files, I download and convert asis -- as it is 2023, we may get 2 TB sd if we wish.There are many way to get tidal file
