See post #788...
It cuts out after a couple of tracks!
Still on the stock firmware though. I didn’t have time to update it before leaving for Büsum.
Quality-wise a great entry level DAP overall and especially given the price and size of the thing, I would wholeheartedly recommend it at this price range.
It felt a bit too bright for my admittedly bass heavy tracks, but details wise I had no qualms (with IEMs).
For those who have tried, I would like to know how easy it is to connect to a DAC/AMP with a USB-C cable since I've always had a finicky time using those things.
Yes, M0 tonality is on a brighter side, but still I'm very pleased with low end extension and impact. Sound stage is above average, layering and separation is average. Dynamics improves when switched to high gain. Zero hissing. It's in line with my expectations for an entry level DAP; actually it exceeds my expectations considering such a tiny size. Plays flac and dsd without a problem. Gapless is fine. Touch screen is more responsive than some of the smartwatches, considering it's size. Can drive even some of the demanding cans loud (like 470 ohm open back R70x), but not exactly to their full potential. Pairs up much better with iems.
With usb-c otg connection, so far I tested with both iDSD (using a cheap $3 usb-c to USB adapter) and HA-2 (using Shanling's own L2 cable). The trick is to turn iDSD and HA-2 first on so it's running off their internal battery, and then connect M0 which detects "audio connected". If you connect first and then turn dac/amp on, they will be draining M0 battery, overhearing it.
The only "bug" with that, which I'm sure going to be addressed in the next fw update, using as a digital transport the playback stops after a short while.
This bug doesn´t exist with the M1, which I´m currently using with my ALO CDM tube DAC/Amp. Sounds bloody superb.
We are working on some more essential functions of our own system. Audiobooks are still planned.
To everybody, can you give us tips on your favorite android/iOS audiobook apps?
Not sure if I'm just too stupid or if it is just a bug since I can't adjust the clock on FW 1.5
Everything else (including battery life on lowest brightness) is pretty much astounding considering it's price.
Not sure if this was answered. Can you add playlist on the fly and if so can you name them on player ?
