Shanling ET3 - Dedicated Digital CD Transport, With USB Drive and Wi-Fi Support
Aug 30, 2023 at 10:13 AM Post #151 of 1,484
Aug 30, 2023 at 11:04 AM Post #152 of 1,484
I was just browsing around and found this product, seems to do everything that I'm looking for... @MusicTeck, is it off the market now?
... and @Shanling - is there something to update/replace this on the horizon?
ET3 will be back in stock this week.
MusicTeck Stay updated on MusicTeck at their sponsor profile on Head-Fi.
https://www.facebook.com/MusicTeckStore https://www.musicteck.com/ info@musicteck.com
Sep 4, 2023 at 9:06 PM Post #153 of 1,484
ET3 was released just two months ago, it's in full production.
Sep 6, 2023 at 10:59 AM Post #156 of 1,484
@Shanling which setting on the Holo Spring 3 DAC work with the I2S out from this CD Player? Thanks
Sep 6, 2023 at 8:33 PM Post #157 of 1,484
Looking at the manual, seems the default Holo setting should be compatible.
Sep 6, 2023 at 8:36 PM Post #158 of 1,484
Much appreciated @Shanling . I shall read the manual for the ET3 as well. Because Jaben in Singapore tell me they should be receiving stock soon. Look forward to trying it out. :)
Sep 7, 2023 at 10:25 AM Post #159 of 1,484
It is a very handy source to play with, it basically has everything you can think of from a digital source.
Sep 7, 2023 at 10:43 AM Post #160 of 1,484
Absolutely! It certainly looks that way! The I2S connector would be great to connect to my Holo Spring 3 KTE. :)
Sep 20, 2023 at 2:29 AM Post #161 of 1,484
Sep 20, 2023 at 3:06 AM Post #162 of 1,484
Sep 20, 2023 at 3:32 AM Post #163 of 1,484
Well, a firmware update is always welcome. Can you tell us if the implementation of CD Text and gapless on DLNA are planned for the next updates?
Regarding Shanling's I2S cable, is there any news? Thank you.
No plans for CD text currently.
Have you tried the new firmware version with DLNA yet?
Shanling L8 cable is now released, please check with your local Shanling distributor/dealer.
Sep 20, 2023 at 4:46 AM Post #164 of 1,484
Yes, I tried DLNA with Mconnect and gapless doesn't work. By giving 'play all', playback stops after the first track activating gapless, while without gapless it reads all the tracks one after the other. With bubbleupnp it's even worse, playback, despite play all, for example before an album,
stops after playing the first track, with or without gapless.
Sep 20, 2023 at 5:02 AM Post #165 of 1,484
I would add one thing, Mconnect with gapless works perfectly using Wiim mini as a renderer. It's the only thing keeping me from removing the Wiim mini from my main system. If a 90 euro streamer can do it without problems, I'm sure the excellent ET3 can do it too.
  • Back
