Tuneslover
Just got my HD6xx and Magni 3 last week. Super impressed with both.
I can't believe how great the 6xx sound. Price/performance ratio is crazy! Paired with the M3, these phones are so balanced and effortless and doing everything right. Bass hits with tight and clear thuds, trebles are all there without sibilance, mid range strong, etc...
For kicks I hooked up my 6xx directly to my Fiio X3ii. Even at high gain and max volume, the sound was not quite loud enough. And it was completely lifeless. So the amp buy was absolutely needed. The numbers didn't lie in this case.
Amp has a huge amount of headroom, so ready for even more challenging phones if I go that route. I'm at 9'oclock with low gain right now and the sound is more than loud enough in a quiet environment. No hissing, or other crap, even when turning the volume knob. Just all goodness.
Next I'm looking forward to comparing my Sines, even though they are a much different phone.
You have a good setup at truly bargain pricing. Goes to show that you don't have to spend a fortune to get excellent performance.
I would like to suggest that an external DAC such as the reasonably priced Schiit Modi Multibit would elevate your system even more. I have the FiiO X5ii as my digital source and feed it into my Modi MB (on to Project Ember & HD6XX) and I can say that although the FiiO DAC is pretty decent, the Modi MB trounces it. Of course I use the FiiO DAP as my portable on-the-go device (with Beyerdynamic DT1350).
