BoomBox
My HD6XX that's about a month old, with a cable + 4.4mm adapter from CustomCans!
Would you like to elaborate and tell us all about it?My HD6XX that's about a month old, with a cable + 4.4mm adapter from CustomCans!
Seriously though... what's the cable like and what are you running them from?My HD6XX that's about a month old, with a cable + 4.4mm adapter from CustomCans!
A DAC is not a DAC. There are definitely subtle differences between DACs. It all depends on how trained and sensitive your ears are. To make it even more fun, you can men generalizations about the DAC chips, but the implementation of the DAC makes a big difference.I'm 'upgrading' from my Grace Design m9xx and not intending to buy another DAC/Amp for a few years.
My options currently look like this:
- Fostex HP-A4BL £299 (Sideways move rather than an upgrade or is balanced a significant improvement despite low power figures?)
- Audio-GD R2R-11 £360 (Single ended only but highly regarded)
- Schiit Jotenheim £520. Seems to do it all but some say qc issues and maybe too bright?
My thinking is that a DAC is a DAC is a DAC to some extent, but for the HD650, the amp would play the most vital role.
With the Fostex being the lowest powered and the Jot the highest, each choice has its disadvantage I guess?
Any assistance would be grateful appreciated as I can't hear any of these before purchase except maybe the Fostex.
i own the R2R 11 DAC. it sounds sweet and musical and it is phenomenal for the price. it has a higher noise floor (background not as quiet as Joteheim)
if you have a lot of planar headphones like Audeze you get better results with R2R11 but if your headphjones are a little easier to drive chord mojo is even better imho
